Brake Bleed Sequence
Old Sep 13, 2003 | 03:57 PM
chucks88's Avatar
chucks88
Default Brake Bleed Sequence
I have both my Helms and Haynes manual open to the brake section......
Helms.........
RF
RR
LR
LF
Haynes.......
LR
RR
LF
RF
Anybody know for sure which is the correct sequence :crazy:
Old Sep 13, 2003 | 04:00 PM
Vette Head's Avatar
Vette Head
Default Re: Brake Bleed Sequence (chucks88)
I'd follow Helm, as it is the GM service manual.
Kirk :seeya
Old Sep 13, 2003 | 04:03 PM
scorp508's Avatar
scorp508
Default Re: Brake Bleed Sequence (Vette Head)
Helms is correct as you have ABS. If you did not have ABS then Haynes would be right.
Old Sep 13, 2003 | 04:12 PM
chucks88's Avatar
chucks88
Default Re: Brake Bleed Sequence (scorp508)
Thanks boys :cheers:
Old Sep 13, 2003 | 05:37 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
:iagree:
Its in the manual.
tony
Old Sep 14, 2003 | 12:02 AM
jfb's Avatar
jfb
When no manual is available, you bleed in descending sequence from the longest brake line to the shortest brake line.
Old Sep 14, 2003 | 01:06 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Chuck: where did you find your Helms manual... have 87 and looking for one...thanks
vinnie
Old Sep 14, 2003 | 08:25 PM
chucks88's Avatar
chucks88
Default Re: Brake Bleed Sequence (vinnies87)
http://www.helminc.com
To Brake Bleed Sequence
