Siamesed TPI base manifold???
Old Sep 14, 2003 | 12:45 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default Siamesed TPI base manifold???
I had heard something about this before. Has anyone here done it or have any info on it?
EDIT: I found all the stuff in the archives about it.
[Modified by SurfnSun, 12:59 PM 9/14/2003]
Old Sep 14, 2003 | 02:27 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default Re: Siamesed TPI base manifold??? (SurfnSun)
I have heard of siamesed runner before but the base??? :confused:
Got pics
Old Sep 14, 2003 | 02:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
This mod started a few years ago on the http://www.third-gen.org/ site; several guys here have also done it with success.
I have done this mod with good success; my L98 now pulls well through 5,800rpm. I believe I lost a little low end torque but it was hard to see even in 60' times; but I've more than compensated by installing a 2,000rpm TC.
There are dyno pulls before & after on my site (link in my sig. below) as well as some pics of this mod. Note that the "after" pulls were a little shakey due to a leaky fuel pressure gauge that was discovered only on the dyno; also, note that on the "after" pulls power is up by 10% (20hp) at 5,400rpm.
I have increased the siamese cut depth another inch for a total of 2" deep but don't have post mod dyno pulls yet.
I feel that with heads & cam this setup will pull into the 6,000rpm, at least that's the target.
Old Sep 14, 2003 | 07:15 PM
cdnguyred88's Avatar
cdnguyred88
Default Re: Siamesed TPI base manifold??? (65Z01)
looks like I've got a winter project to add to the ever growing list!!!! :D
:lolg:
Old Sep 14, 2003 | 09:36 PM
65Z01's Avatar
65Z01
Default Re: Siamesed TPI base manifold??? (cdnguyred88)
Well sure, but think of all the "hours of fun" you'll have for under $100.....
:jester
Old Sep 14, 2003 | 09:44 PM
Paul G's Avatar
Paul G
Can it be done with the base on the car?
Old Sep 14, 2003 | 09:55 PM
65Z01's Avatar
65Z01
Default Re: Siamesed TPI base manifold??? (Paul G)
No way! And you need to flush the base runner tubes thoroughly to remove all Al powder and shavings.
Old Sep 14, 2003 | 11:53 PM
devilfish's Avatar
devilfish
I did it. And im running a hotcam, ported heads. It pulls like mad to 5800rpm.
I traped 108mph with that setup UNTUNED ;)
To Siamesed TPI base manifold???
