Front left Wheel loose... need advice.
Old Sep 16, 2003 | 08:11 PM
dbwade36's Avatar
dbwade36
Default Front left Wheel loose... need advice.
The front left wheel is loose when I pull it back & forth. (right side is tight). It looks like the inner arm? (attached to the rack & pinion) . Sorry, that I don't know the name, but it is the part that is covered by a boot on outside of the R&P. I know that this will wear my tire out quickly. I want to replace it, but need to know if I should just go OEM, or something aftermarket? Also, what the Heck is it called. inner rocker arm? Anyways, opinions would be helpful. thanks.
Old Sep 16, 2003 | 08:39 PM
95AquaC4's Avatar
95AquaC4
Default Re: Front left Wheel loose... need advice. (dbwade36)
Upper/lower control arm? :confused:
Old Sep 16, 2003 | 08:44 PM
O'Shark's Avatar
O'Shark
It sounds to me like it's a loose tie-rod end. That's nothing to mess around with either. I was in a '65 Impala that had one break at speed. I'd repair that ASAP :yesnod:
Old Sep 16, 2003 | 08:46 PM
Southern Comfort's Avatar
Southern Comfort
well...I have been reading your posts with great interest and sympathy. Sounds like you are having as much fun as I am. My latest mod......I find my car on the rack at a transmission shop. :lol:
Old Sep 16, 2003 | 08:52 PM
dbwade36's Avatar
dbwade36
Default Re: Front left Wheel loose... need advice. (Southern Comfort)
Yes, that's it! Inner Tie Rod. So, I guess I will get that fixed ASAP. Should I just go OEM, or aftermarket? Does Summit sell them?
Old Sep 16, 2003 | 08:56 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I think you may be referring to the tie rod...it is the straight link from the steering rack to the wheel(knuckle).
Yes, it should be repalced fairly soon if it is very noticeable..shouldn't be that much $
:seeya
:steering:
Old Sep 17, 2003 | 12:36 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Drive down to your local jobber and i'll bet he has it in stock for half the price of G.M. :smash: :smash:
Old Sep 17, 2003 | 12:55 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Steve: sorry to hear that.... :(
Old Sep 17, 2003 | 08:15 PM
dbwade36's Avatar
dbwade36
Default Re: Front left Wheel loose... need advice. (vinnies87)
Update: GM wanted $113 for the Inner Tie Rod. I found it at Kragen for $57 & I get a 10% military discount there, so about $50 for the part. I will need the 4 wheel alignment after install of rod, so found a place that will charge $70 & a friend gave me a 50% off coupon on alignment at that shop- SO, the bottom line is good news: Part $50, Alignment $35. Grand total to fix problem $85. (must say, it is better than what Firestone wanted. If they ordered the part & installed it, & did alignment, they wanted $340! Outrageous! $120 for an alignment is BS, even if it is a Vette.
My story is done. :)
To Front left Wheel loose... need advice.
