Fuel pump suggestions....
Old Sep 19, 2003 | 01:02 AM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Default Fuel pump suggestions....
Well my car has 156k on her and a want to replace the fuel pump. I've heard that its not too hard and with some forum help it'll be a breeze. I need some suggestions on a fuel pump purchase. Which type should I buy? I want something to last and when I upgrade the engine/components to supply them in the 350hp or up range...Thanks-Eli
Old Sep 19, 2003 | 01:44 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Fuel pump suggestions.... (2nd2SEX)
Since a fuel pump delivers flow not pressure I suspect our stock pump can deliver enough fuel to build 350chp or so and still maingain pressure.
I installed an OEM AC Delco pump with matching pickup screen.
