Reading Codes for a 95
Old Aug 17, 2003 | 01:52 PM
aggie88's Avatar
aggie88
Default Reading Codes for a 95
I have the 95 "Hybrid" OBD-I with the OBD-II connector. Is is possible to read codes without a code reader/scanner? According to the Actron website, I need the OBD-II scanner since the 8th digit on my VIN is a "P".
[Modified by aggie88, 12:53 PM 8/17/2003]
Old Aug 18, 2003 | 06:38 AM
aggie88's Avatar
aggie88
Default Re: Reading Codes for a 95 (Oldman)
Thanks Oldman, this is promising:
"For 1994 and later models, you will need to recover the codes using a special procedure involving the speedometer and the odometer as explained in the service manual or use a special diagnostic device known as a scan tool."
But my "Shop Manual" does not have the procedure referenced. Anyone with a "Service Manual" can help?
Old Aug 18, 2003 | 06:44 AM
aggie88's Avatar
aggie88
Oldman - never mind - found the link on the previous URL with that procedure. Thanks again!
Old Sep 18, 2003 | 09:44 PM
thewalk's Avatar
thewalk
Default Re: Reading Codes for a 95 (aggie88)
would you mind putting that link up here? i am having a heck of a time finding a scanner that will work on my '94!
Thank you! :smash:
Old Sep 19, 2003 | 02:10 AM
aggie88's Avatar
aggie88
Default Re: Reading Codes for a 95 (thewalk)
That is weird - why did oldman's post iwith the URL disappear? Anyway here is the link:
http://www.c4vettes.com/facts_launch.htm
To Reading Codes for a 95
