Changing valve stem seals with the Intake off?
Old Sep 19, 2003 | 04:53 PM
montie98's Avatar
montie98
Default Changing valve stem seals with the Intake off?
Hello, Is there anything to know or do I just follow the same procedures as if the intake manifold was still on the car? I was wondering if it was easier or not?
Old Sep 19, 2003 | 05:07 PM
fullboogie
Default Re: Changing valve stem seals with the Intake off? (montie98)
Just make sure you use compressed air to pressurize the cylinders before you remove the spring/locks/retainer assembly, or you're going to drop a valve!
Old Sep 19, 2003 | 05:41 PM
SBNova's Avatar
SBNova
Its not at all neccessary to remove the intake to change the valve stem seals. Use a compression tester and hook it to an air compressor to continuously fill the chambers with pressurized air. I also tap the retainer carefully with a small hammer to break the "seal" between the retainer/locks/and stem prior to using the spring compressor. I also recommend having one of those magnet-on-a-stick things to help retrieve those pesky locks once they're loose.
Old Sep 19, 2003 | 07:15 PM
montie98's Avatar
montie98
Default Re: Changing valve stem seals with the Intake off? (SBNova)
Since the intake is going to be off anyhow I was hoping this would somehow make it easier, guess not, Thanks guys
Old Sep 19, 2003 | 10:42 PM
Switch's Avatar
Switch
Make sure and use a rag or something to keep the keepers from dropping into places that you wouldn't want them to.
Like was mentioned, compressed air, rap of a small hammer, and magnet it will be easy.
Gordon
www.witchhunter.com
Fuel Injector Cleaning & flow testing
To Changing valve stem seals with the Intake off?
