Fastburn 385 with hotcam...
Old Sep 20, 2003 | 08:21 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Default Fastburn 385 with hotcam...
Well my engine has 157k and I was looking into crate engines. I have the Scoggin-Dickey performance catalog. Inside is the Fastburn 385 with hotcam and its going for around $4,800. The engine makes 430hp at 6000rpm and 430ft/lbs @ 4400rpm. Just needs some of the tin and intake I believe. Well I want the engine. Has anybody thrown one in their car or something similar? Also would I be able to run a miniram with this engine? or would a different intake best complete this engine? :seeya
[Modified by 2nd2SEX, 7:23 PM 9/20/2003]
Old Sep 21, 2003 | 07:48 PM
BILLYD's Avatar
BILLYD
Default Re: Fastburn 385 with hotcam... (2nd2SEX)
TTT
I'd like to know too
:confused:
Old Sep 21, 2003 | 07:59 PM
SPEED750's Avatar
SPEED750
Default Re: Fastburn 385 with hotcam... (BILLYD)
The intake "THATS WHERE THEY GET'CHA". Most all the crate motors I've seen use a carb.It seems like everybody can make an old school sbc with a carb out turn 400+ hp.I would like to see what kind of numbers these motors would turn with a well tuned fuel injection. :rolleyes:
Old Sep 21, 2003 | 08:02 PM
tjwong's Avatar
tjwong
Unless that Mini-Ram is machined to be bolted onto a Votec Head style bolt pattern, NO it won't work. However I do beleive that Scoggin Dickey makes a TPI base for the Vortec bolt pattern. So that means you could use a Super Ram.
http://www.sdpc2000.com/cart.asp?act...1460&pid=13740
Old Sep 21, 2003 | 08:07 PM
VetteNoob's Avatar
VetteNoob
Default Re: Fastburn 385 with hotcam... (tjwong)
TPIS makes a vortec MR now.
Old Sep 22, 2003 | 01:13 AM
ElisTwoCents
Default Re: Fastburn 385 with hotcam... (VetteNoob)
A vortec miniram intake...Well thats news! Would it flow enough to get me thosr numbers? Aside from that it should bolt up in my car being a 350 right..? 700R4 would go in just fine right...
Old Sep 22, 2003 | 06:06 PM
opel's Avatar
opel
Now if they would just make a super ram intake that would bolt right up to my Vortec heads.
:flag
Dave
To Fastburn 385 with hotcam...
