front suspension ?????
Old Sep 21, 2003 | 07:18 PM
ladystoy69's Avatar
ladystoy69
Default front suspension ?????
anyone know anything about a code hkx front spring from 84-87 vette ??? lmk thanks
[Modified by ladystoy69, 12:45 AM 9/22/2003]
Old Sep 21, 2003 | 07:38 PM
bogus's Avatar
bogus
Default Re: front suspension ????? (ladystoy69)
huh?
HKX? is this written on the spring?
Old Sep 21, 2003 | 07:49 PM
ladystoy69's Avatar
ladystoy69
Default Re: front suspension ????? (bogus)
i am looking to buy one and this guy emails me saying he has one for sale and tells me the code and years so i guess yes that is the number on the spring anyone know what it is? what is the ride quality what stiffness? anyone?
Old Sep 21, 2003 | 11:05 PM
ladystoy69's Avatar
ladystoy69
someone has to know ????? :confused:
Old Sep 21, 2003 | 11:57 PM
redvette1986's Avatar
redvette1986
If you can get under the car (passenger side) you can read the code that your car has. My 86 had the HKX...soft ride. I bought a second hand spring that was marked FJY (also soft ride)....the replacement worked great. So, I guess the HKX and FJY are interchangable....does this help?
Old Sep 22, 2003 | 12:15 AM
ladystoy69's Avatar
ladystoy69
Default Re: front suspension ????? (redvette1986)
yes that helps some but do you know how it would match up to a Z51 spring???
Old Sep 25, 2003 | 05:09 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My '85 Z51 front spring is marked FHU.
The '85 spring rates are:
base: 308 lb/in
Z51 : 363 lb/in
In '86, there were 3 front springs from the factory. The convertibles had a slightly stiffer 'soft ride' spring than the coupes. This probably accounts for the HKX and FJY codes.
base coupe: 296 lb/in
base 'vert: 311 lb/in
Z51: 380 lb/in
To front suspension ?????
