ZF trans question
Old Sep 22, 2003 | 03:54 PM
kawboy5792's Avatar
kawboy5792
Default ZF trans question
I missed a shift into 2nd the other day, and now whenever i try to shift into that gear there is a grinding noise and vibration, but it will go in. the grinding is worse the faster you are going. Once it is in gear, everything is fine. Is this a synchro problem or what? Is this something i can fix or should i take it in?
Old Sep 22, 2003 | 07:06 PM
6spd's Avatar
6spd
Default Re: ZF trans question (kawboy5792)
it does sound like a synchro problem, more then likely you will need to rebuild it. if you are going to go throught the trouble to pull out the tranny and take it apart rebuild it. it is costly $2.000-$2.500
Old Sep 22, 2003 | 07:11 PM
NavyVet's Avatar
NavyVet
Did you try double clutching the 1-2 shift? If it shifted without noise, you probably killed a synchro. Which, on a ZF, is not cheap. At least it doesn't sound like a gear. BTW, I would not force it into 2nd with the 'gridning' you describe. You will only make matters worse. Bits of loose metal inside the tranny mean more problems soon. :flag
Old Sep 22, 2003 | 07:14 PM
Nathan Plemons's Avatar
Nathan Plemons
Ouch. Tranny must have been hurting to begin with. I've missed second way more times than I would like to admit and the synchros still work. It had to have been on it's last legs when you did it.
Old Sep 23, 2003 | 01:16 AM
froggy47's Avatar
froggy47
Default Re: ZF trans question (Nathan Plemons)
:iagree:
One missed shift kills zf6 tranny, don't think so.
Old Sep 23, 2003 | 07:40 AM
Aaron71771's Avatar
Aaron71771
No good, the trans must have been ready to pop. I would take it easy until you are ready to have the trans rebuilt. Give zfdoc a call or email. www.zfdoc.com
Old Sep 23, 2003 | 08:54 AM
larryfs's Avatar
larryfs
sorry to say 1 missed shift will damage a ZF :eek:
my 20,000 mile ZF is whining in 4th due to 1 missed shift. It was perfectly quiet before that 1 miss. It still works fine, but I definately ruined a syncro.
how many people on this forum complain of noisey ZF's???
every single owner. and that is because of a blown shift resulting in a hanging syncro.
Then I had another blown shift due to CAGS, just once, and now 1st gear isn't 100% perfect anymore.
me personally, I won't fix it till it completely stops working.
Old Sep 23, 2003 | 08:59 AM
bogus's Avatar
bogus
Default Re: ZF trans question (larryfs)
Larry - your 96 has a different version of the ZF6. GM actually made them here... the earlier ones were made in Germany, by ZF.
In 1994, GM tried to "quiet" the gear whine. That in effect weakened the gearbox.
If you have a late model ZF6, replace it with a pre-94 ZF6 and you will be fine... the original, 89-91's are the best, 92-93's are very good, but after that, they are above average, but not as great.
Old Sep 24, 2003 | 11:27 AM
NavyVet's Avatar
NavyVet
Default Re: ZF trans question (bogus)
:iagree:
To ZF trans question
