30 POUND SVO
Old Sep 23, 2003 | 12:03 AM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 30 POUND SVO
I have a 383 stroker with 200 cc dart pro heads, forged pistons, crower valve train, accel intake, superram plenum and runners, lingenfelter afpr, tpis full length headers, flow masters, 160 stat, schnieder cam (intake camlift .320 at 50 degrees is 210, exhaust lift .320 at 50 degrees is 216),3:54 gears, and Accel 24 pound injectors and a custom burned Ed wright chip. I went to get my chip redone after i added my superram and eliminated my cold start. Ed does not program for Accel injectors anymore so I either had to deal with the crappy starts or go with another type of injector. I just ordered Ford SVO injectors from Jegs as per the reccomendation from one of Ed's employees. These new injectors are 30 pounders. So before I tear off my superram for the third time Id like to know if these are going to work. Ive read alot of posts with the pros and cons on injectors. Is anyone running 30 pound Ford injectors and how do you like them. Any problems? :crazy:
Old Sep 23, 2003 | 02:51 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: 30 POUND SVO (PMARTINEZ92126)
I am running them and never had any problems. I have used them for the last two years and about 5K miles.
Old Sep 23, 2003 | 04:44 PM
Darkness's Avatar
Darkness
Default Re: 30 POUND SVO (Vette92)
Do a search for them on a mustang board or on ebay, you can pick up a set of used ones with low miles for less than $100. They're not called SVO anymore, look for FRPP. :cheers:
Old Sep 23, 2003 | 04:48 PM
vvv90's Avatar
vvv90
Or how 'bout keeping your accel injectors installed, return the SVO's and get a chip burned by someone who is actually willing to help their customer.
Do a post in the scan and tune section for people who burn chips.
Or IM ski_dwn_it (aka Jesse) I'm running his chip with no complaints.
To 30 POUND SVO
