How long can Mobil 1 sit?
Old Sep 23, 2003 | 08:57 PM
Bradley33's Avatar
Bradley33
Default How long can Mobil 1 sit?
I plan on putting my car up for the winter soon. I may even leave it up next summer, so the car might sit for 18 months or so.
I'm planning on changing the oil before I put it away, the current oil is about 1year and 3k miles old.
If I leave my car sit that long will I have to change the oil again when I get it back out? Or, should I just leave the oil I have in it for storage and change is fresh when I get out?
Old Sep 23, 2003 | 09:04 PM
JF_AH_64's Avatar
JF_AH_64
Default Re: How long can Mobil 1 sit? (Bradley33)
If I was you I would change it before I put it up for storage and again when I take it out of storage at the very least.
Old Sep 23, 2003 | 09:17 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: How long can Mobil 1 sit? (JF_AH_64)
Why even change it .
Put in fresh when its ready to drive.
Its just going to sit in the pan anyway.
Old Sep 23, 2003 | 09:33 PM
REW89's Avatar
REW89
I don't want to start another long discussion on oil but if you think the only use of the oil will be for storage would dino oil be better for the car for storage?
SInce it is just sitting anyway would the seals be less affected by the dino oil?
Just a thought. Bob :confused: :skep:
Old Sep 23, 2003 | 09:35 PM
Bradley33's Avatar
Bradley33
Default Re: How long can Mobil 1 sit? (AGENT 86)
That's what I was thinking.... but everyone seems to recommend changing it
Old Sep 23, 2003 | 09:44 PM
Darkness's Avatar
Darkness
There's no need to change the oil before storage. In fact my grandfather use to drain all fluids before a long storage. He had a 62 in storage for 16years this way and it was looking as good when it came out as it did when it went in. :cool:
Old Sep 23, 2003 | 09:50 PM
vader86's Avatar
vader86
It would be better to change it when you take it out next summer.
You should at least, if youre gonna leave it up, drive the gas tank empty next summer. Then put it back up if you wish.
Old Sep 24, 2003 | 06:16 AM
93 ragtop's Avatar
93 ragtop
Default Re: How long can Mobil 1 sit? (vader86)
Im going to go against the grain on this one. I say change it before storage. Why? To get rid of the contanimates in the oil that are there from 3000 miles of use. A lot of these are corosive. The gas in the tank is a different matter. Not sure how long gas can be stored with additives such as sta-bil in it. But assuming you can go the 18 months with it I would fill the tank up or completely empty it. If the vette is sitting in a unheated garage, and has some gas in the tank, but not full, you stand a good chance of getting condensation inside of the tank.
Old Sep 24, 2003 | 10:48 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: How long can Mobil 1 sit? (93 ragtop)
:iagree:
All the contaminents in the oil need to be removed. Change the oil now and then store it. There shouldn't be any need to change it again because it won't have had time to build up the contaminents.
Old Sep 24, 2003 | 11:06 AM
bvs3's Avatar
bvs3
Default Re: How long can Mobil 1 sit? (Nathan Plemons)
Doesn't Mobil 1 break down if it sits though?
Old Sep 24, 2003 | 05:00 PM
93 ragtop's Avatar
93 ragtop
Default Re: How long can Mobil 1 sit? (bvs3)
I hope not. I purchased 8 of the 5 qt bottles from wal mart and I wont use them in 2 years
Old Sep 24, 2003 | 05:11 PM
Strick's Avatar
Strick
Mobil 1 will last a lot longer than dino oil. And I too believe changing oil before storage is better.
Old Sep 24, 2003 | 09:46 PM
George Dickel's Avatar
George Dickel
:iagree:
:iagree:
That is how lawn mower mfg recommend storing one over the winter. There is all kinds of crud and acids in that oil. When you park it for the winter the engine has that contaminated oil in all the oil journals, bearing surfaces, etc. Over an extended time that stuff will damage metal surfaces and cause unnecessary wear. Change the oil, run it for a few minutes to get fresh oil everywhere, shut it off and leave it.
Old Mar 23, 2015 | 04:30 PM
sharpseadog's Avatar
sharpseadog
I agree, you want uncontaminated oil in the engine for storage. Also be sure the engine has been run at least 15-20 minutes with oil at full temperature immediately before last shutdown. Also, in addition to full tank with "Sta-Bil" added, it would be really good to use non-ethanol gas for the storage fill, even if you can only find it in mid-grade. 10% Ethanol gas gums up terribly in less that 3 months. That will cause more trouble than running a tank of mid grade.
Old Mar 23, 2015 | 05:21 PM
DGXR's Avatar
DGXR
Change the oil before putting it in storage, to remove the corrosive & acidic contaminates in the used oil. Yes motor oil contains neutralizers to counter effect acids and other harmful things, but motor oil is very cheap. Also you don't want that bad stuff sitting in your engine and not giving the oil good heating and circulation so it can do its job. Change it again when you take it out of storage, just because the oil has been sitting in an open system for so long (not in a sealed & clean container). 1 year or 7500 miles, whichever comes first.
Think how much trouble you are taking to store it properly, and possibly how much you will pay for storage if it's not on your property (not sure of your situation). Regardless, changing the oil is a no-brainer.
New oil in the jug, even unsealed jugs with tight lids, will keep for years and still be good. Some argue that without being shaken or agitated, some additives will settle out if it sits completely still for years. I don't know about this. I do buy extra oil when it's on sale and sometimes it sits for a year or more, never had an issue.
Old Mar 23, 2015 | 07:42 PM
arbee's Avatar
arbee
I sure hope nobody sat around waiting for your contribution - this thread is twelve years old!
Old Mar 23, 2015 | 08:02 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
To How long can Mobil 1 sit?
Old Mar 23, 2015 | 09:41 PM
Silver96ce's Avatar
Silver96ce
And I doubt the OP will ever see his reply - he hasn't posted since 2003!
Old Mar 23, 2015 | 10:06 PM
RollaMo-LT4's Avatar
RollaMo-LT4
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
So, it is probably safe to assume the oil is now ready to be changed.
Old Mar 24, 2015 | 06:31 AM
Lloyd Smale's Avatar
Lloyd Smale
I agree. Id change it before then when I took it out id run that oil for about 500-1000 miles and change it out.
