I want to buy another one of these to relocate my Intake Air Temp sensor to the fornt of the intake. Anyone know if Autozone or someting to that effect sells one of those? I am looking for the plastic ones, not the metal ones that screws into the upper plenum.
Don't know if this is the one you want or not. It's for a 91 from Autozone.
Unit Price: $7.99
Core Value*: $0.00
Part No.: SU109
Weight: 0.1 lbs.
Warranty: 3 MO
Availability: Online: Ships within 2 business days
Store: Normally Stocked
Thanks everyone. I'll be picking it up locally by the looks of things. I forgot it was plastic on the LT1's. I knwo it is not a major mod, but it helps a bit due to the colder air it sees entering the intake, and since the superram runs quite cooler than my stop TPI used to, it might be worth a degree of timing advance or two. I've been running mine a bit far down the intake by the ram air scoop, but I'll put it farther up in front of the TB, for a mroe precise temp measurement. I just want a spare one in case I 'F' mine up.
