EXTRA CREDIT QUESTION
Old Sep 25, 2003 | 08:27 PM
loflyin's Avatar
loflyin
Default EXTRA CREDIT QUESTION
On 1986 HEI, what would prevent the bypass signal from being sent?
At 4 pin connector (and at ECM) white and purple have signal, ground is good, but nothing on tan/black. Continuity is good back to ECM. No signal there either (even if circuit was open, shouldn't there be voltage at the beginning of the line?). Dist and ECM grounds are good. Chew on it and throw me some ideas, cause I'm fresh out. Thanks. :banghead:
Old Sep 25, 2003 | 08:33 PM
ffvetteman's Avatar
ffvetteman
Default Re: EXTRA CREDIT QUESTION (loflyin)
No extra credit points for me :cry
:steering:
Old Sep 25, 2003 | 09:27 PM
loflyin's Avatar
loflyin
Default Re: EXTRA CREDIT QUESTION (ffvetteman)
I am not clear as to the interior of the ECM. Unsure what functions are grouped into each quad driver, do the dist signals go/come from a quad driver or straight from the PROM. Is this just a bad ECM, PROM, somehow a fault with the dist or maybe.....something as dumb as an open in a door ajar circuit could cause this. Need someone with more knowledge to help. There are people on this forum that know the answers. Pride keeps me from taking it to a shop, Finances are covering Pride's back on this one. I'm just the poor schmuck caught in the middle. :confused:
Old Sep 25, 2003 | 09:42 PM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
You will get a better response if you make your post title a bit more descriptive. I know me, unless it's something I can add to or am interested in, I usually skip right over the topic because things are so sluggish.
Dialups suck.
It's bad enough waiting 15-20 seconds for a post to load, so most people are gonna only go with what reaches out and grabs them as worthy of loading... :chevy but sorry, I'm not too swift when it comes to the electronics side of things, probably my least favorite thing to do on the car, chasing bad grounds and stuff... :U
[Modified by TrueBlue ChevyDude, 9:44 PM 9/25/2003]
Old Sep 25, 2003 | 10:22 PM
loflyin's Avatar
loflyin
Default Re: EXTRA CREDIT QUESTION (TrueBlue ChevyDude)
Tried that. This is the third time in 2 weeks that I have tried. 1st post-no one responded. 2nd post (in scan and tune) - gentleman answered some questions aboutthe values that I was gettnig and then said to get scanner and software. 3rd try - well here we are. Obviously, this is one of the tougher questions as few responses compared to views. :crazy:
Old Sep 25, 2003 | 10:29 PM
screamingeagle's Avatar
screamingeagle
Try going into the corvette assembly plant site, i'm pretty sure they have a contact page. If anybody would know those guys would. Sorry i'm not going to be much help either, if it was about avionics or electricals on a blackhawk I might be some help. Keep us posted though, I want to see how it turns out :lurk:
[Modified by screamingeagle, 3:31 AM 9/26/2003]
Old Sep 25, 2003 | 10:30 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
No points for me either.
:flag
Old Sep 26, 2003 | 12:35 AM
loflyin's Avatar
loflyin
Default Re: EXTRA CREDIT QUESTION (oldace84)
Screamingeagle, don't think you're getting off so easy. After vette is straight, Blackhawk is now at the top of my wish list (I'll have my own personal mechanic). :D
And guys, I appreciate you taking the time to think about it. If it were an easy question, I would have known the answer. At least you have taken the time to tell me that you don't know either- way better than no response at all. I'll try the plant site, but I don't hold out much hope there. Have a great night! :sleep:
Old Sep 28, 2003 | 09:53 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Please accept my apologies if I misunderstood your post, but the ECM doesn't put 5v on D5 until engine speed reaches @400 rpm. If you're checking the tan/black wire with engine off, I dont think you will read anything. Are you having a code 42 problem. Will the distributor never go into ECM control for timing? I must have missed the previous post, so again my apologies.
To EXTRA CREDIT QUESTION
