Have Miniram - does it need more porting?
Old Sep 25, 2003 | 09:39 PM
ZD1's Avatar
ZD1
Default Have Miniram - does it need more porting?
Have Miniram III - does it need more porting? For the money spent... I am looking to get a lot of power/flow outta this thing...What should I do?
The part came port matched to gasket already.
Old Sep 25, 2003 | 10:40 PM
danno85's Avatar
danno85
Default Re: Have Miniram - does it need more porting? (ZD1)
What heads are you going to use that with? And does yours mount with
6 bolts on each side or 4?
Based on what mine looks like, I wouldn't think any additional porting would
do good.
Dan
Old Sep 25, 2003 | 11:41 PM
reallycoolcorvette's Avatar
reallycoolcorvette
no additional porting. the cam is nice and should idle nicely with the wider LSA.
Old Sep 26, 2003 | 12:32 AM
ZD1's Avatar
ZD1
Default Re: Have Miniram - does it need more porting? (danno85)
I have the fast burns and the intake looks to use the late model 6 bolts attachment setup. Fastburn have both vortec(8) and late model intake holes.
do good.
Dan
Old Sep 26, 2003 | 08:44 AM
danno85's Avatar
danno85
Thanks for the info. That's the way mine is too - 6 bolts on each side with
the center two machined for either straight or angled bolt holes. I'm running
the fastburn heads too. I was curious because I bought mine on ebay and
it was advertised as a miniram III but then I didn't know how to tell for
sure. It does have raised ports to match the fastburn heads.
What intake gasket are you going to run?
Thanks,
Dan
Old Sep 27, 2003 | 12:39 AM
ZD1's Avatar
ZD1
Whatever they put in the box! I'm not too picky as long as it's not in the way of the intake port. I always use plenty of gasket maker-no cork.
Old Sep 27, 2003 | 05:27 PM
ZD1's Avatar
ZD1
Whatever they put in the box!!!
Old Sep 27, 2003 | 11:13 PM
danno85's Avatar
danno85
What did they put in the box?
Old Oct 6, 2003 | 07:38 PM
danno85's Avatar
danno85
Felpro 1289
Excellent - thanks for the info :thumbs:
To Have Miniram - does it need more porting?
