Fuel injectors opening time??
Old Sep 29, 2003 | 02:27 PM
Tomas's Avatar
Tomas
Default Fuel injectors opening time??
Hello everyone
I have now a custom chip with a fuel injectors opening time set to 1,7ms with a 30lbs/hrs injectors. But this winter im gonna go for more power and bigger injectors, maybe 40-50lbs/hrs. What opening time do you have with that large injectors??
thanks
Tomas
Old Sep 29, 2003 | 02:39 PM
drive it's Avatar
drive it
Default Re: Fuel injectors opening time?? (Tomas)
It's not opening time, but duty cycle that determines what size inj. you need....
The commonly accepted formula is inj. pulse width X rpm divided by 600=inj. duty cycle (for batch fire)
For sequential inj. pulse width X rpm divided by 1200= inj duty cycle.
And you don't want to go much over 80% duty cycle.
Don't go too big-it then gets difficult to tune for idle areas.
Old Sep 29, 2003 | 02:53 PM
Tomas's Avatar
Tomas
Default Re: Fuel injectors opening time?? (drive it)
Hello Drive it
Thanks for the reply. What size of injectors do you think i should go for? I have drive 11,72 with my car so approx 450-500Hp i should have?? This winter i will try to get more power, but i dont know how big injectors i should go for?
Old Sep 30, 2003 | 11:49 AM
tjwong's Avatar
tjwong
Tomas, in normally aspirated trim 30lb units are still adequate. To calculate injector size use this formula:
(Horsepower x BSFC) / (Number of inj x Duty cycle)
BSFC = .50 for normally aspirated engs, .60 to .65 for blown, and turbo
Duty cycle = .80 (80%) in normal applications for sizing
Where are you in Finland? I have been to Helsinki and I spend 6 weeks in Tampere a few years ago.
[Modified by tjwong, 8:55 AM 9/30/2003]
Old Oct 1, 2003 | 03:07 AM
Tomas's Avatar
Tomas
Default Re: Fuel injectors opening time?? (tjwong)
Hello tjwong
thanks for the reply. If I calculate with this formula with approx. 500Hp I must have 50lbs/hrs injectors, I have drive with 30lbs since -99 my with my setup.
I live here in Finland http://www.aland.fi/virtual/eng/frame.html
To Fuel injectors opening time??
