I need to replace the radio antenna on my 85. Is this a complicated procedure? I have ordered the antenna from Zip Products. Are there any tricks, etc. that I need to be aware of?
84-88 Antenna Removal:
Disconnect neg battery cable
open hatch, remove rear trim panel
disconnect antenna lead from the relay
remove left side trim
remove luggage shade
remove left side carpet trim, pull back
remove left trim panel
raise and support vehicle
remove inner fender screws and brace open for access
remove antenna ground strap
unfasten plastic nut at top of mast
remove antenna bracket nuts
remove power and antenna leads by pulling them through the body
remove antenna from vehicle
transfer bracket and ground
** install do reverse....
Vinnies87 is correct. I just replaced my 84 antenna, just be patient and buy a manual. During my career I learned that when all else fails, read the manual.
Sometimes getting the nut on the top of the mast loose can be a bear. There is only room for one hand and then it is at an angle. I used a faucet wrench with an extra long extending handle on mine. The faucet wrench is like a pipe wrench where the jaws are 90 degrees to the handle and the jaws flip over to tighten or loosen. I could get one hand up to the nut and hold the wrench in place and then turn the handle with the other hand.
I fixed mine the cheap way. Bought a fixed antenna off a Chevy at the junk yard and mounted it instead of the electric. It is black and looks like the C5 antenna. :thumbs:
