wtf??
Old Sep 29, 2003 | 07:30 PM
Feenix566's Avatar
Feenix566
Default wtf??
alright so i go to check the ECM for error codes. i connect pins A and B, being the two rightmost pins on the top row of the Assembly Line Data Link, expecting the "check engine soon" light to start flashing. but instead, the radiator comes on. :skep: :confused:
Old Sep 29, 2003 | 07:36 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: wtf?? (Feenix566)
From what I understand that trips all the relays too.
edsalinas's Avatar
edsalinas
St. Jude Contributor
I believe it's A to G ???? Far right top/bottom.
Old Sep 29, 2003 | 07:40 PM
Topless87's Avatar
Topless87
Default Re: wtf?? (edsalinas)
No A-B top 2 right should be shorted prior to key-on possition is correct. Then turn on key and it should start flashing codes. Do not short A-G. The fan will come on. It does on mine at least.
Old Sep 29, 2003 | 07:46 PM
scorp508's Avatar
scorp508
The fan should come on and then your SES light should blink code 12, trouble codes, code 12. The 12 just means "entering diagnostic" and "exiting diagnostic".
Old Sep 29, 2003 | 07:48 PM
Corvette0096's Avatar
Corvette0096
Default Re: wtf?? (scorp508)
:iagree:
Old Sep 29, 2003 | 08:01 PM
edsalinas's Avatar
edsalinas
Default Re: wtf?? (Corvette0096)
I stand corrected. It's A & B, from the good book.........
To wtf??
