Engine harness swap questions, need info.
Old Sep 30, 2003 | 03:56 PM
LD85's Avatar
LD85
Default Engine harness swap questions, need info.
This winter I am considering putting a 165 engine harness into my 85.
What year harness should I opt for?
Does the engine harness effect the dash controls?
Can I change the harness with the engine in the car?
BTW, Painless Wiring has an off he shelf harness (#60102) for the 86-89 vette .
http://www.painlessperformance.com/m...90503mhome.htm
Old Sep 30, 2003 | 04:12 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Engine harness swap questions, need info. (ld85)
I would shoot for the 89, last year for the MAF.
Never really gave the dash much thought. I would contact painless, I'm sure one of their technicians can quickly and efficiently assist you.
I have worked with a few things from them, and they have it going on! Their stuff is a pleasure to work with. Great quality, dependable, definately the way to go.
I am especially interested in how this project goes. We are seriously thinking of making the 67 chevelle 509 CI merlin into a SD car. Although I would like to go with MAF, ducting etc, will be too hard to come/fabricate.
Definately keep us all posted on what you find out. Good luck larry.
:cheers:
Old Sep 30, 2003 | 06:06 PM
LD85's Avatar
LD85
Default Re: Engine harness swap questions, need info. (ski_dwn_it)
Looks like the early 86 is the only direct swap, 88 has a different alternator connection and the late 86, 87, 88 had optional Climate Control
or
A Painless Wiring 86-89 custom harness is available, I will check with them again..
[Modified by ld85, 8:00 PM 9/30/2003]
To Engine harness swap questions, need info.
