Does ECM use MAF sensor during open loop?
Old Oct 2, 2003 | 09:38 PM
GRX's Avatar
GRX
Default Does ECM use MAF sensor during open loop?
Like title says. L98, 1985. I know it only starts reading off the O2 sensor when it goes closed loop (and of course the MAF sensor). ...but I'm wondering about MAF usage during "open" loop. TIA!!
Old Oct 2, 2003 | 09:42 PM
88_vette's Avatar
88_vette
Default Re: Does ECM use MAF sensor during open loop? (GRX)
yep
Old Oct 2, 2003 | 09:44 PM
GRX's Avatar
GRX
Default Re: Does ECM use MAF sensor during open loop? (88_vette)
...but isn't it possible to run the motor without the MAF in open loop?
Old Oct 2, 2003 | 09:58 PM
tjwong's Avatar
tjwong
You can once it starts and stops a couple times and goes into fuel back up mode. Then it reverts to Speed density mode and runs off the VE tables.
Old Oct 2, 2003 | 09:59 PM
GRX's Avatar
GRX
Default Re: Does ECM use MAF sensor during open loop? (tjwong)
So it reads the TPS, RPMs and VE tables in open loop? This is an 1985...no MAP here...
[Modified by GRX, 7:00 PM 10/2/2003]
Old Oct 3, 2003 | 12:47 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The only L98 engine control sensor that is ignored in open loop (such as at WOT) is the O2 sensor.
In this case the ECM reads and records the O2 sensor values as ususal but it sets two parameteres, the Block Learn Mode (BLM) cell #15 value and the Integrator value, to "neutral" value of 128. Since both of these values always read 128 in open loop, no modifications are made by the ECM to the A/F ratio. In closed loop mode O2 sensor readings are used to trim two parameters, which in turn trims the A/F ratio by adjusting injector pulse width to the correct values for driving conditions.
Old Oct 3, 2003 | 05:50 PM
vetracer's Avatar
vetracer
Default Re: Does ECM use MAF sensor during open loop? (65Z01)
I think you just answered a question I have long wondered about open loop/closed loop/BLM's. I wondered how a computer controlled car such as the Corvette could be running rich or lean if the computer/o2 sensor are constantly monitoring/adjusting the A/F ratio. Seemed to me that chip programming would be futile if the ECM is going to add or subtract fuel based on O2 readings in closed loop. If WOT puts the car into open loop and the A/F ratio is determined solely by the tables programmed into the chip, then that explains how the A/F ratio could be rich or lean and therefore affect performance. Am I getting this right? :skep:
To Does ECM use MAF sensor during open loop?
