Rear end grinding noise
Old Oct 3, 2003 | 09:47 AM
MrWiggly's Avatar
MrWiggly
From: Sunny Seaside Seabrook Texas (a whole 'nother country)
Default Rear end grinding noise
I hear a short "grinding" type noise coming from the rear wheel/area (1992 C4) at 2-3 mph when first starting out in the morning. Is this positrac needing lube? Anyone else have this problem?
Old Oct 3, 2003 | 10:40 AM
vader86's Avatar
vader86
Default Re: Rear end grinding noise (Lordmrwiggly)
Could be a wheel bearing, they usually quiet down when you get moving.
Jack up the rear, and grab the wheel at 12-6 and pull in and out. If you get any play, its the bearing.
May as well replace the U-joint on that side too.
Old Oct 3, 2003 | 10:58 AM
Steel Blue 91's Avatar
Steel Blue 91
I think what you are hearing is your ABS unit self testing. It is in the compartment directly behind the driver. You should also see the ABS light come on while the unit "moans".
[Modified by Steel Blue 91, 10:59 AM 10/3/2003]
Old Oct 3, 2003 | 11:02 AM
vader86's Avatar
vader86
Default Re: Rear end grinding noise (Steel Blue 91)
:iagree: could be the ABS too
Old Oct 3, 2003 | 11:11 AM
dwestsr's Avatar
dwestsr
Default Re: Rear end grinding noise (vader86)
I hear a whirring noise in the rear of my 86 coupe first time it is driven for the day. It lasts for a second or two. I've been wondering what that was. It is not a wheel bearing noise so it is probably the ABS self test. If yours is a grinding noise and not a whirring noise , it is probably wheel bearing. Good Luck
:cheers:
Old Oct 3, 2003 | 12:26 PM
bstirn's Avatar
bstirn
My 92 does the same thing when I first put It In gear and go in the driveway only when Its cold . Im sure Its the ABS .
Old Oct 8, 2003 | 06:33 PM
chief253's Avatar
chief253
My 93 moans as well, but I don't remember the light coming on :confused:
Old Oct 8, 2003 | 07:11 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Rear end grinding noise (chief253)
:cheers: ABS test comes on when you approach 4 mph, forward or reverse. You should hear a moan/groan and feel a brake peddle reaction. Hot or cold shouldn't make a difference.
If you are concerned about rear end and haven't changed the fluid or added the GM posi additive in a while, I would!@
:seeya
:steering:
Old Oct 8, 2003 | 07:13 PM
Goody's Avatar
Goody
Default Re: Rear end grinding noise (jackdaroofer)
All this talk about moaning, grinding and rear ends is giving me ideas. :jester
To Rear end grinding noise
