half shaft U-joint
Old Oct 3, 2003 | 10:07 PM
1990CORVETTE's Avatar
1990CORVETTE
Default half shaft U-joint
If I have a 2 jaw puller for the tie rod end ,,, mark the cam bolt on the spindle support rod and remove,,, and finally remove the leaf spring will this allow enough play in the knunckle to remove the half-shaft.
Old Oct 3, 2003 | 10:20 PM
tworottiedogs's Avatar
tworottiedogs
Default Re: half shaft U-joint (1990CORVETTE)
I did mine a little different: http://temp.corvetteforum.net/c3/2ro...s/index3.shtml
I didn't want to mess with tierods or marking of the spindle.
[Modified by tworottiedogs, 10:21 PM 10/3/2003]
Old Oct 3, 2003 | 10:22 PM
scorp508's Avatar
scorp508
:yesnod:
http://personal.tmlp.com/scorp/vette/images/ujoints/
Old Oct 3, 2003 | 10:31 PM
1990CORVETTE
Default Re: half shaft U-joint (scorp508)
Thanks scorp 508
a really big help,, how long did it take you to do this?
To half shaft U-joint
