What about these mods?
What I intend to do: ported plenum, SLP's high-flow cast aluminum TPI intake runners (siamesed), Big Mouth Tpi Base Intake Manifold, rear Y-pipe with crossover pipe and Monza or Dynomax mufflers. Also, an adjustable fuel pressure regulator. Maybe, in the near future, 1.6 roller rockers.
I definitely do not want to go into the engine at this time for financial reasons.
What can I expect from these mods? I do not expect to break any speed records and this car is my daily driver so it has to remain streetable and mantain decent mileage.
What do you think of these mods? NOTE: I intend to keep the stock 48 mm Throttle Body.
You should get some noticible (at least in the 1/4 mile) gains from those mods.
For a real boost to driving pleasure consider a 2,000rpm TC and a Trans Go shift kit. The TC will overcome any low end losses from the siamese runners and the shift kit will make driving a lot more fun. Even at moderate throttle I get a nice chirp on the 1-2 shift; in cool weather she even wags the tail on the 1-2 shift.
I have similar mods and get maybe a little better mileage on the highway.
bump up the timing to 8 degrees (for starters)
remove the freesbie
move the IAT sensor :smash:
Remove the screens and fins from your MAF
Also, a Servo kit is much cheaper than shift kit, and you can easily install it yourself. It will also make the shifts much more firm. If you want even harder shifts, you can always add a shift kit later.
I've read that a 2600 9" TC will drop 3 tenths off your 1/4 and still does fine for everday driving. My stock TC will stall to 2000rpm.
I agree with Headers. (Summit has long tubes for $120)
Also, True dual 2.5 exhaust (local muffler shop here did mine for $220)
X-pipe (magnaflow x-pipes off ebay for $65)
Servo Shift kit ($70)
March Power AMP pulley set ( 3 pulleys w/Alternator overdrive to retain stock
charging-- ($130)
It's a never ending story :)
Just disconnect the brown/black striped wire. Now with the timing light you will see the initial timing at 6 degrees. Bump it up to 8 degrees. Hook the wire back up and your finished. You can keep bumping up the timing until you set off the knock sensor, and then set it back a little. I've read that some have run 9-11 degrees.
It made a noticable difference for me. I've read a few articles that said that the car went from spinning the tires to smoking the tires after bumping up the timing.
