how many 350/355 doing 11s here?
Old Oct 6, 2003 | 04:00 PM
devilfish's Avatar
devilfish
Default how many 350/355 doing 11s here?
could you post your setups.
( N/A )
Old Oct 6, 2003 | 10:14 PM
Hole-Shot's Avatar
Hole-Shot
Default Re: how many 350/355 doing 11s here? (devilfish)
Forum member bjankuski recently pulled an 11.9xx @ 111 mph with a 355 ci.
Forum member "Ralph" has a stock bottom end and think his bet et is a 11.6xx
These are the only 2 that come to mind off hand.
Check out Beach Bums "proven setups" page. Lots of info on his site.
:cheers:
Old Oct 6, 2003 | 11:32 PM
bjankuski's Avatar
bjankuski
I just ran an 11.97 at 111.55, my mods are in my sig.
Old Oct 7, 2003 | 02:11 AM
Darkness's Avatar
Darkness
Default Re: how many 350/355 doing 11s here? (bjankuski)
Does N2O or Forced Induction count? :D
Old Oct 7, 2003 | 04:43 AM
devilfish's Avatar
devilfish
Default Re: how many 350/355 doing 11s here? (Darkness)
no..
Old Oct 7, 2003 | 09:49 AM
ralph's Avatar
ralph
SR/219/190s/PT converter and almost any gear will work. I've gone a best of 11.62 and a best mph of 117.6 in -800ft DA. I now run a little heavier for consistency and she'dl usually go 11.8s in 1000ft DAs, that is until i had the converter loosened...big mistake. Need to have that undone over the winter.
Old Oct 7, 2003 | 10:53 AM
Eric Fischer's Avatar
Eric Fischer
Rich S has gone 11.8's in his LT4.
Old Oct 7, 2003 | 11:33 AM
Hole-Shot's Avatar
Hole-Shot
Default Re: how many 350/355 doing 11s here? (ralph)
and she'd usually go 11.8s in 1000ft DAs, that is until i had the converter loosened...big mistake. Need to have that undone over the winter.
Ralph, how loose did you go with the converter? What did you have previously?
Hole-Shot
Old Oct 7, 2003 | 05:12 PM
ralph's Avatar
ralph
Default Re: how many 350/355 doing 11s here? (Hole-Shot)
The converter was their std 2800 stall unit. And it probably flashed to 2900-3000. It was plenty tight on the street, so i figured i'd have it loosened a bit since my torque peak should be around 4000 rpms. I didn't want to lose any mph and they assured me they could loosen it about 200-300 without hurting the efficiency. WRONG!!!!
It doesn't feel any looser to me and the car 60s about the same, but it's hurt after that. I estimate i lost almost a tenth and 2-3 mph in the 1/4 with all increments suffering after the 60 foot mark. I assume it's the converter since its the only thing i've changed since last year. I've gone over everything else i can think of. Going to have Protorque undo the change after the season.
Maybe i'm trying to squeeze too much outa this setup. For the last 3 years, everything i've tried hurt me considerably and i had to undo it.
Old Oct 7, 2003 | 08:15 PM
RichS's Avatar
RichS
Default Re: how many 350/355 doing 11s here? (Eric Fischer)
Stock LT4 bottom end in pretty decent weather and traction. I backed it up twice that day also. :cheers:
Old Oct 7, 2003 | 08:25 PM
Corvette0096's Avatar
Corvette0096
I am almost there. 113MPH is a good sign.
To how many 350/355 doing 11s here?
