[L98] hard to start
Old Oct 6, 2003 | 04:43 PM
slapvettehead's Avatar
slapvettehead
Default [L98] hard to start
:seeya can any one tell me what could cause hard start after an hour or two with the engine hot, but if i start it up after a shot time it fires up ok, i have had to replace the temp sensor (ECU) i suspect it could be the MAP sensor???? :banghead:
Old Oct 6, 2003 | 05:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: [L98] hard to start (slapvettehead)
If it satarts right up when cold but hard after a few hours I would suspect leaking injectors.
To check this out, hold the accelerator to the floor for a few seconds before cranking a warm motor. If it starts right up then it was flooded by leaking injectors.
You can send a set of injectors to Rich at Cruzin Performance (link on my site, see sig. below) and he will recondition and flow test them for around $10/injector with 48hr shop time.
Old Oct 6, 2003 | 05:38 PM
slapvettehead
Default Re: [L98] hard to start (65Z01)
Cheers il give it a go :cheers:
To [L98] hard to start
