I can't seem to get my parking brake to adjust!!! I figured out how to disable the self adjuster but what do i need to do in order to tighten up the cables?? Is there a place to adjust them somewhere?? My self adjusting parking brake seems to be working somewhat but not good enough to hold the car once I put it in drive. Thanks in advance
Re: Need Parking Brake Adjustment Help!!!! (Wheelman)
You might want to check the condition of the pads and the e-brake mech is not
jammed. My passenger side actuator lever was ceased and required me to
disassemble, lube and reassemble. My brake didnt work and cable would
not adjust until I ripped the mech apart. From there I had to pull both rear wheels
and adjust from there. My two cents....
I have the same problem with my 93. New pads and it still won't hold. Self adjuster appears to be working. Can't get an inspection sticker till it does. I haven't tried adjusting the caliper yet, however.. That may have to wait until spring. :flag
