'84 engine stumble
Old Oct 9, 2003 | 04:37 PM
kevin_darlington's Avatar
kevin_darlington
1st Gear
Default '84 engine stumble
Can anyone tell me why when my car is in a controlled slide why
the engine stumbles? It does this whether the tank is full of gas or has hardly in it. It acts like it isn't getting fuel or something. Any help with this would be a road racers dream. Thank You.
Old Oct 10, 2003 | 11:29 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: '84 engine stumble (kevin_darlington)
Kevin,
I've never had this problem, but maybe you could check out the guys at the CrossFire Forum http://www.crossfire.webhop.net
Been alot of help for my '84.
Good Luck
tony
Old Oct 10, 2003 | 11:11 PM
ben73's Avatar
ben73
Hey Kevin,
Check your fuel pressure, should be between 10 and 13psi..
'84 fuel pumps are crap, get an '85 pump and install it instead.. Also check that the short piece of rubber tube that connects the pump to the steel fuel lines (inside the tank) is intact...
To '84 engine stumble
