Weird problem...
Old Oct 9, 2003 | 09:49 PM
JF_AH_64's Avatar
JF_AH_64
Default Weird problem...
The other day I was driving on the interstate at about 65 and whenever I would give it alot of gas I would get a sort of knocking, it almost felt the same as when you have the transmission in to high a gear for your speed. There was no jump in RPM's so I am ruling out a slipping clutch. If I just gave it a little throttle it was fine, could this be the optispark or could it just be bad gas. It has also taken a second to start sometime in the last few days, fuel pump. I know I am throwing around alot of ideas, thanks for your help.
Old Oct 9, 2003 | 09:55 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Default Re: Weird problem... (JF_AH_64)
Maybe the dual mass flywheel is going???
Old Oct 10, 2003 | 01:15 AM
Flyboy1963's Avatar
Flyboy1963
Cruising
Hey, does it hesiate or stumble when you rev it up from idle? And run like crap at highway speeds in 6th gear (assuming you have a 6spd)?
Old Oct 10, 2003 | 11:46 AM
JF_AH_64's Avatar
JF_AH_64
Default Re: Weird problem... (Flyboy1963)
No, it runs fine when i rev it from idle, and I can punch it in 1-4 without any troubles, its when i shift to 5 or 6th that it starts to stumble.
Old Oct 10, 2003 | 11:50 AM
jfb's Avatar
jfb
Check your initial timing. 5th and 6th provide a heavy load on the engine and if it is too far advanced, pinging will occur.
Old Oct 10, 2003 | 04:06 PM
JF_AH_64's Avatar
JF_AH_64
Default Re: Weird problem... (jfb)
Ok well i went out and drove it today, and it died on me at a red light and did the same thing as I had described previously. When I got home I decided to check all the plug wires and sure enough one had touched and melted a little against one of the egr tubes, could this be the reason for my problems.
Old Oct 10, 2003 | 10:40 PM
jfb's Avatar
jfb
Yes, that can cause your symptoms. Heavy engine loads require a good spark, and high cylinder pressure requires higher plug voltage to jump the gap. A melted plug wire may jump at the melt rather than at the plug under heavy load causing a miss.
To Weird problem...
