Turbo Project
The xmas holidays are coming up very soon, and it is time 2 start the work on the 1988 vette, after taking a ride in a STi last night i have changed my mind on putting a sc onto the vette and are going for the TWIN TURBO Project!!!
Now this will be a first for me as i have never work on turbos, so im going 2 take it slow and hopfully it will be all done by Feb 14th 2004 (in time for my bday)
Im not sure if i should sell the L98 and buy myself a Lt4 or lt1 tune and stroke that then install the turbo in that. I will have 2 get the turbo custom made, same wit the i/c anyone got any ideas where i can get that done.
My oldman got all the tools in the world and if he doesn't we will be able 2 get it easy from his work, so installion will be done by me, my oldman and my mates (dont think they will help much ahahaha)
I think i will upgrade brakes 2 z06 or c5 type brakes, and reinforce the d44 and do the rest off the stuff 2 the handing ect. after i get an est. on the hp i will make with the turbo (as this is kind of my 1st /2nd car and im only 17 i think 500 or 650rwhp will be ok for the start )
Wish me luck for the 1st turbo vette in australia (i think)
Cya Michael
Now im not 2 sure on which turbo 2 get most people with turbo c4 are using the PT52 (2 of them), now at $675
Comes with T04E Compressor Cover - 3" Inlet and 2" Outlet, large 60 trim comp wheel, T350 76 trim turbine wheel, .63 or .85 A/R.
For high 10 second applications, 3000 minimum stall required.
These turbo's require a specific wastegate actuator for true bolt-on compatability, sold seperately.
Supports up to 600 hp at the flywheel.
doesnt seem 2 bad; the next few models T64E ect just add an extrat 100hp (700hp at the flywheel) and are $300 more in price. Hmm do u think it is worth the extract $$$ ....?
Does anyone have any idea where 2 start looking..?
You might be better off getting the Sycloon ot typhoon Turbos with the built in watsegates, This is what I was thinking about, supports 375HP each. :yesnod:
Or you can mount it high which would help with the oil return, but you need room for all the pipes. Remember you are going to have 3" exhaust comming out of each of these turbos that would need to get from the top to the bottom of the car around everything. Around the headers or where ever you route them.
I hope you are good at welding and cutting pipe. Youre gonna have to make your own headers or hire a welder to do it for you. There's alot of planning into it and it's going to be very expensive.
As for the turbo go to http://www.chapturbos.com The guys there know there stuff and they'll hook you up right. You'll probably want a T3/T4 Hybrid turbo with a .84 or .96 turbine housing and a 60-1 HIFI Compressor housing. You may be able to get an internal wastegate on these, but more likely than not with the size you will want to run you're going to have to have an external gate.
I do know alot of this from experience try searching for "beltless boost" and you'll see my turbo project atempt. Good Luck, and if there's anything I can help with let me know. Oh yeah, a supercharger would be SOOOO much easier.
[Modified by mn_vette, 3:50 PM 10/10/2003]
that link u gave me http://www.chapturbos.com didnt work, also i was planning on using the same setup as this c4 turbo vette http://www.jdhcon.com/Vette.html
The 2 turbos are place on Each side of the i/c
Turbo ---------------- Turbo
--------------I/C-------------
Get the idea? is this a good setup? maybe i should get your number so i can make some phone calls when i get stuck and dont know wat 2 do (which will be like every second ahahaha :jester )
[Modified by Soulja_350, 2:06 AM 10/11/2003]
Turbo --- I/c --- Turbo
The other thing you might want to think about is doing a single turbo. It makes the intercooler easier, and you only have to find space for one of them. Which in some cases will make all the difference. It's just something to think about. The turbo itself isn't all that big, but it's finding the room for all the pipes and othere such stuff going to it that becomes the problem. Proper planning will make all the diffence.
If you'd like to give me a call I'm usually free evenings Central US time. 1-507-269-6354. International calls could be a bit expensive so forum or email (mckevett@us.ibm.com) or chat (AOL IM: assashi ) might be best.
After talking it over with my dad, the setup used by http://www.jdhcon.com/Vette.html looks like the best idea, my dad is a very hands on type of guy, i showed him the pics
and
and he said yeah we can do it just take our time and it can be done
So are u saying the PT52 Precision Turbo with .85 AR Ratio, will be 2 big? as i would like 2 built my turbo setup around one that is already working
Also Money, and time isnt a problem as i also own a poopiety $1000 car which gets me from a 2 b and works fine, so the vette is kind of my weekend supercar. (money is a problem but as time isnt money will increase over time :jester )
[Modified by Soulja_350, 2:37 AM 10/11/2003]
http://www.twinturbovette.net/Home1.htm
Another good person to talk to would be monty(forum name) check his sig and you'll like it.
Oh, yeah, don't forget about your new ecu you'll need for the car too.
I wanna pre-set the psi lvl at 6,8,10,12,14,18,20 and 22. and if i really want 2 get it 2 be a daily drive i guess i can drive it at 6psi.
Yeah the block work should be done by feb14th, turbo maybe 2005 feb :D, i got exams and stuff coming up so not alot of work will be done for about 2months after that i will get stuck into buying all the stuff and planning everything. I also plan on C/F most of the car (doors,targa,hood (wit high-rise), bodykit,) and change the glass 2 take off alot of the weight and add a roll cage for safty.
Tranny and read end, will be a similar setup 2 the one at http://www.jdhcon.com/Vette.html
With the wastegate is it possable 2 have 2 let out the smoke (that is wat i call it) not into the exhuast but on the side of the car kind of like the nos value system (the pic i am thinking of is the skyline of 2f2f get the pictuer?)
Anywayz it is midnight, so i better head off 2 bed got a big day 2morrow, i will catch up on the posting when i wake up Cya!
I am not following you all that well on the part about the 2F2F skyline. That was N2O being sprayed out of it. the wastegates wont make smoke like that. mainly noise. unless you mean, your just referencing where you wanna dump the exhuast out.
I imagine, it will produces a very loud sound, will this be legal? Maybe it would be possable 2 have 2 piping from the wastegate
1. into the exhuast piping
2. into the side of the car (vent the exhaust directly to the atmosphere)
and have a switch 2 change where 2 goes *just a crazy idea*
[Modified by Soulja_350, 1:59 PM 10/11/2003]
[Modified by Soulja_350, 2:22 PM 10/11/2003]
I was also over at http://www.greenline.jp and was looking at a few of the j-spec products for that type of stuff, it looks like they are only built 2 fix j-spec cars, i will try and find out if they will work on a v8 turbo setup
