84 C4 doesn't like left turns
Old Oct 12, 2003 | 11:35 PM
pwrbtr's Avatar
pwrbtr
Cruising
Default 84 C4 doesn't like left turns
Driving normally, left turns no problem. When turning left and getting a little spririted, the engine dies mid way through the turn. Only happens when the fuel tank is 1/4 or less. Anyone have this problem before? I'm fairly certain it's a fuel pick up problem. It it common in 84s?
:cheers:
Anthony
Old Oct 12, 2003 | 11:45 PM
ben73's Avatar
ben73
Default Re: 84 C4 doesn't like left turns (pwrbtr)
Check that the short piece of hose that connects the pump to the steel fuel lines (inside the tank) is intact... Mine was swollen and had no hose clamps fitted.... Replace this with a short piece of fuel hose with clamps and your problem will disappear :) :)
Also, 84 pumps are crap, they are flat out holding proper fuel pressure (10-13psi) under load.. The 85 pump works alot better in this case..
Come on over to the Crossfire Forum at http://www.crossfire.homeip.net:81/cftest/default.asp
You will have to register to read the message boards.
Just about everybody there runs an '85 pump!
Seeya,
Ben.
Old Oct 13, 2003 | 12:54 AM
pwrbtr's Avatar
pwrbtr
Cruising
Thanks Ben, I've been a lurker there for a while, trying to get up to speed on the crossfire.
:cheers:
Anthony
Old Oct 13, 2003 | 09:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's a common problem. The gas gauge sucks .
Keep your tank fuller !!
:cheers:
Old Oct 13, 2003 | 09:55 AM
Nathan Plemons's Avatar
Nathan Plemons
I've never starved my car for fuel in a curve, but I've certainly done it on the straights. Any time I'm around 1/4 of a tank I just lay off of it until I can get gas or I'll slosh it away from the pickup. There might not really be anything wrong with your car, just a small design flaw.
To 84 C4 doesn't like left turns
