In an '88 Vette the 4 cluster bulbs can be accessed from the front...Remove the screws from the bezel, remove the telescope handle, loosen the dash pad hold down screws along the front and slide out the bezel...Then remove the silver caps covering the bulbs and remove the bulbs.
Really??? Cool!!! I looked in my parts manual, and only saw 4 "Plugs, heat sink" accessible from the front...But I can see the upper left "plug" must be where the burned out bulb is...
Thanks for the heads-up! :thumbs:
Halogen??? JFC, why is everything on a Vette so high-buck??? :cuss
