For everyone running headers.....
Old Oct 13, 2003 | 05:49 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default For everyone running headers.....
Mark your calendars, daytimers, PDA's, email systems to remind you to tighten the header bolts every few weeks! I let mine go for like 3 months and forgot all about tightening them.....
I was showing some punk in a new M3 that he cant pass me, when POOF! What annoying sound when those things let go!
I spent half of saturday replacing the passenger gasket, and tightening the drivers side headers. DONT FORGET LIKE I DID!!!! :smash: :smash:
Do they make copper header gaskets like the ones for the collectors?
Old Oct 13, 2003 | 06:01 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: For everyone running headers..... (GusBustamanteJr)
Summit offers copper header gaskets
Old Oct 13, 2003 | 06:32 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Also try JEGS. http://www.jegs.com
Plenty of help/parts.
tony
:flag
Old Oct 13, 2003 | 07:05 PM
Nathan Plemons's Avatar
Nathan Plemons
They make copper collector gaskets but I've found that the dead soft aluminum ones actually work better down there. They crush a little bit and conform to any imperfections in the shape.
As for the header bolts themselves I found that if you put a little bit of ARP assembly lube on them it will let you get them a lot tighter without any effort. I just looked up my old post and figured out that it's been a full year since I put the heads on my car. I tightened the header bolts then and have not had a single one loosen the least little bit.
Old Oct 13, 2003 | 07:09 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: For everyone running headers..... (Nathan Plemons)
It also helps to have Stage-8 Locking Header bolts :)
Old Oct 13, 2003 | 07:16 PM
GusBustamanteJr
Default Re: For everyone running headers..... (TIMSPEED)
Do I have to work my way up from Stage 1 or can I jump right in at stage 8???? :jester :jester
I have never heard about them, got any pics?
Old Oct 13, 2003 | 07:25 PM
J Z06's Avatar
J Z06
Thanks for the heads up. :cheers:
Old Oct 13, 2003 | 07:40 PM
korvette4u's Avatar
korvette4u
u could also use Stainless Steel Bolts to tighten your headers, lube them with "Coppercoat Anti seize compound"
Old Oct 14, 2003 | 12:27 PM
TheStef's Avatar
TheStef
Default Re: For everyone running headers..... (korvette4u)
If I get some long tube headers.. can I use the stock bolts?
Old Oct 14, 2003 | 12:34 PM
Goody's Avatar
Goody
Default Re: For everyone running headers..... (TheStef)
Usually no because of side clearance issues. Need a smaller head for them to fit.
Old Oct 14, 2003 | 01:32 PM
ninetyfivevette's Avatar
ninetyfivevette
Default Re: For everyone running headers..... (Goody)
Using the copper header gaskets can be tricky. I tried them when I blew out one of mine and I could never get them to seal properly. Apparently the "correct" method to install these is to remove the exhaust from the headers, tighten the header bolts, and then bend the exhaust pipes as necessary such that no stress is being placed on the headers themselves, otherwise with the extra thickness of the copper gaskets, they will never seal totally. This probably would not have been a problem had I used the copper gaskets to begin with and had the exhaust built around these gaskets instead of the much thinner original gaskets.
After failing with the copper gaskets, I went with the FelPro header gaskets with LT1 ports (pn 1406) with some high temp copper RTV and I have been very happy.
Old Oct 14, 2003 | 03:50 PM
tjwong's Avatar
tjwong
Default Re: For everyone running headers..... (ninetyfivevette)
I use stainless steel ARP fasteners with square wire lock washers. I tightend them down once, then rechecked after a couple heat cycles. They have been on there for over a year now and have not loosened up after this last check a few weeks ago.
Old Oct 14, 2003 | 04:24 PM
Vothweirdon's Avatar
Vothweirdon
Default Re: For everyone running headers..... (tjwong)
:iagree:
With Hooker Headers I never had any problems (with the lower cost ones I always had issues with them sealing correctly)
Voth
Old Oct 15, 2003 | 11:48 AM
TheStef's Avatar
TheStef
Default Re: For everyone running headers..... (Vothweirdon)
For those of you with the L98 engines, did you keep the EGR system intact?
or did you remove it?
I pretty much know the proes and con's of keeping it or removing it... but I'm wonder if it would be a hard job to keep the system intact with the headers.
I'm wondering if there is a lot of welding involved.
Old Oct 15, 2003 | 02:59 PM
NavyVet's Avatar
NavyVet
:iagree: With Timspeed - get the Stage-8 bolts - they won't come loose unless you take the retainer clip and wide washer that locks against the header off on purpose. The only way to go. :flag:
Old Oct 18, 2003 | 05:03 PM
JAKE's Avatar
JAKE
I dumped mine long ago, no welding either. I make a plate to block off the location where EGR bolts to the manifold and removed all the associated hoses and wires. I had the EGR turned off in the PROM too so there are no SES lights to bother me.
Hope this helps.
Jake
Old Oct 18, 2003 | 05:12 PM
GlockLT4's Avatar
GlockLT4
I'm running ARP stainless steel 1" 12point bolts. They look nice and seem good to me. Only problem is tightening them down. Hard to get them tight. I had to use an 8mm wrench with not much room, so very difficult. No way to get a torque wrench in there. Any recommendations on getting them really tight? What torque should headers be at anyway? :confused:
To For everyone running headers.....
Old Oct 18, 2003 | 05:17 PM
VetteNoob's Avatar
VetteNoob
Default Re: For everyone running headers..... (GlockLT4)
My manual said only 25 ftlb on the exhaust manifold bolts for my L98. Dont figure the LT1s are any different.
Old Oct 18, 2003 | 05:55 PM
Midgetfist's Avatar
Midgetfist
:iagree: - hypothetically. I just received a custom set from Stage 8 in the mail today. I ordered them Thursday evening and received them Saturday morning - fast and friendly service. The TPIS LT's will go on the LT4 Tuesday.
Old Oct 18, 2003 | 10:39 PM
88_vette's Avatar
88_vette
Default Re: For everyone running headers..... (Midgetfist)
I put copper seal RTV on the threads. No much but a little bit this holds them in nice.
