supercharger
Old Oct 15, 2003 | 12:08 PM
SJLJ's Avatar
SJLJ
Default supercharger
Just a question- can a supercgarger be put on a car whose only modifications are a KN open filter and a Corsa exhaust system? If so, what should be the expected horsepower? Just curious
Old Oct 15, 2003 | 12:37 PM
tjwong's Avatar
tjwong
Default Re: supercharger (SJLJ)
Depends on what year your car is and who the kit supplier is. Most will advertise a 40 to 50% increase in power. And when you install the kits, your present air filter arrangement is usually removed and replaced with something from the kit. The Corsa will just enhance the kit. Remember, its input equal output. With all that air going into the engine it has to get out as well, your Corsa wil just enhance that over the stock system.
Old Oct 15, 2003 | 03:00 PM
SJLJ's Avatar
SJLJ
Default Re: supercharger (tjwong)
Car is a '95 LT1
Old Oct 15, 2003 | 03:06 PM
vvv90's Avatar
vvv90
Take a gander in the C4 Forced induction forum on the left. Better yet, do a search for any topic you'd like. You'll learn a lot from searching the archives.
:cheers:
Old Oct 15, 2003 | 03:45 PM
smallblock's Avatar
smallblock
you'll need the proper fuel enrichment and timing adjustments to avoid detonation and broken pistons :eek: :eek:
To supercharger
