Borla Muffler Inserts?
Old Oct 16, 2003 | 12:26 AM
rsafier's Avatar
rsafier
Default Borla Muffler Inserts?
I have heard that blocking off one of the tailpipes on each side of my Borla mufflers would help reduce/stop the resonance I have. Does this really work, and if so are there inserts I can buy or do I have to make them?
Old Oct 16, 2003 | 07:20 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Borla Muffler Inserts? (rsafier)
On some Borla's only one tail pipe is functional
As far as resonance, welcome to the Borla Deaf! I understand a cros over pipe in the rear Y pipe helps
:seeya
:steering:
Old Oct 16, 2003 | 10:46 PM
rsafier's Avatar
rsafier
Default Re: Borla Muffler Inserts? (jackdaroofer)
:seeya
:steering:
Well my set both tailpipes on each muffler are active, can see straight thru the thing. I love sound, except when under about 65mph. I do have the cross-over pipe. I had that put in with the mufflers. So can't compare without it. Really annoying resonance under acceleration between 1200-1500, once you get to about 1700 its all but gone.
I've done the other "fixes" like crossover pipe, moving the muffler tips as far back as possible. This is my last idea.
Old Oct 17, 2003 | 07:00 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:seeya
:steering:
:cheers: On my Borla's, the resonance never quits! Right up to wot!
:seeya
To Borla Muffler Inserts?
