Charging Problems Maybe
Old Oct 16, 2003 | 08:30 AM
eagle6's Avatar
eagle6
Default Charging Problems Maybe
my 1994 coupe is showing 14.5 to 15.0 on the voltmeter al the time. Is this normal or does anybody have any ideas as to what is going on or what should I check? What is the normal volt metter reading for my gauge suppose to read?
Old Oct 16, 2003 | 09:30 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Charging Problems Maybe (eagle6)
my 87 runs 14.2 charging...
Old Oct 16, 2003 | 11:01 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Up to 14 is ok particularly right after cold startup.
15 ANYTIME is getting out of 'safe' range.
COULD be the internal VR (voltage regulator) inside your alternator. It's replaceable.
It's about the only thing in there that will cause the voltage to go too high.
Higher voltage =higher current the battery/electrical system is dissapating.
Higher than design parameters= not too good.
A LOT of folks replace the whole alternator but us CHEAPER folks out here always find the least expensive ways to fix stuff.
And.. we almost NEVER "PAY" anyone to fix anything for us.
Good luck with it.
Old Oct 16, 2003 | 11:04 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Whoa, I see you have a 94.
I'm not SURE the VR is internal to your alternator.
It "MAY" be in the CCM or Central Control Module on your 94....
Somebody else chime in please... and enlighten us.
Old Oct 16, 2003 | 11:47 AM
jfb's Avatar
jfb
Measure the voltage across the battery terminals and compare it with your dash voltmeter. The design center voltage for charging is 14.7 volts and going higher than that increases the charging current . You may just have a voltmeter that is slightly out of calibration. I believe GM says maximum charging voltage is 16.0 volts.
Old Oct 17, 2003 | 11:02 PM
eagle6's Avatar
eagle6
Default Re: Charging Problems Maybe (jfb)
I had the battery replaced a year ago at the dealership with the best one they make for that year.
Old Oct 21, 2003 | 12:13 PM
eagle6's Avatar
eagle6
with just the the key turned on what voltage reading should I get as far as voltage I found it was a little weak starting today?
Old Nov 2, 2003 | 11:04 PM
eagle6's Avatar
eagle6
Thanks for all the help. I replaced the starter and everything seems to be fine back down to 14.2 & 14.1 voltage reading.
To Charging Problems Maybe
