When Should Timing Chain Be Changed (L98)?
items with the timing chain should be changed at the same time? Average labor hours to accomplish this? My engine is at 65k miles.
Also....how much more labor is involved with changing the cam at this point?
The cam thing is always in the back of my mind, but the labor hours must be a killer.
[Modified by bradvette, 4:19 PM 10/16/2003]
As far as time to do the job, who is doing the job? If a mechanic is doing it just call a shop and find out what the flat rate manual says because that is how much time they will charge you for, not how long it takes them. Most mechanics can do a job in much less time than what the manual says. If I was doing it, probably most of the day because I am slow and meticulous or slow and old, I forget which.
Changing the cam will require you to remove the intake manifold in addition to everything it takes to remove the timing chain.
The wife always asks how long do I think it will take me to do something on the car and whenever I quote a number of hours it invariably takes twice that because of unforseen problems. In all honesty it would problably take me a weekend to change the chain and cam. For a novice, probably a lot longer.
You gotta talk to Scorp about how long it takes to do it.
The chain generally doesn't break,... they wear down to the point where the engine gets tired. At the extreme's it can start to backfire.
The wear depends mostly on the oil maintenance.
Is it worn,... it is a visual thing. You could take a few measures,... but it still easier to just pull the cover and have a look. ANY slack in the chain will have an effect on power output. The HEI is at the tail end of the mech slack in the engine. i.e. proper spark control = max power Slack in chain, slack in gears = bouncing spark timing. Ka-pe-sh?
A decent replacement for the $,... Cloyes double roller,... street version. Set it up on the advanced keyway to compensate for chain stretch.
I believe Gates or Goodyear has a web site where you can look up engines and tell if it's an "interference" (sp) engine. Smaller overhead cam engines tend to have problems with piston to valve clearnace when belts fail. Ugly.
A stock 350 should not be a problem.
Wouldn't change anything till you have a problem, change the cam, or doing work where you suddenly have major access to the timing cover. 70K miles or so, I'd probably leave it alone.
Drive on.
dlmeyers 90 coupe zf6 3 speed shocks
