How loud is the ZF with an aftermarket alum singe mass Flywheel
Re: How loud is the ZF with an aftermarket alum singe mass Flywheel (BAD ZR1)
I'll go 9.0. Sounds like the bearings are shot. I also noticed that it was different depending where you were standing around the car. Went back to a stock DM when I built my 383, and don't regret it.
Think like your driving a diesel truck. I've had people stare at me at lights due to the noise when I drove the car on the streets. Just push the clutch in and watch the look of confusion on their faces as the sound goes away.
Larry
Larry
Re: How loud is the ZF with an aftermarket alum singe mass Flywheel (ered95)
Doe's a sprung disk lessen the gear noise any? :cheers:
Re: How loud is the ZF with an aftermarket alum singe mass Flywheel (TOO_HOTTVETTE)
My thoughts are that it is completely unacceptable to use the extremely heavy, high inertia, and down right dangerous, cast iron dual mass flywheel. I'm planning to put in a McLeod "magnum Force" 2 or 3 disk clutch and flywheel. (with 7 lb! aluminum flywheel).
I will try some of the noise abatement techniques such as some additional sound insulation over the trans tunnel area, and kevlar scatter shield blankets over the bellhousing and transmission body, and of course an exhaust that rumbles ;) . If that proves to be too noisy for me, I'm going to pull the ZF6 and put in a D&D performance chevy adapted Viper T56.
Re: How loud is the ZF with an aftermarket alum singe mass Flywheel (AS84)
On mine, when the engine temp gets warm and when the car is idling in neutral it sounds alot like a spun bearing.
Stopping it is only a push of the clutch away, but it IS NOISEY.
