'88 L98, getting "pinging under hard acceleration
Old Oct 19, 2003 | 08:07 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default '88 L98, getting "pinging under hard acceleration
This has been developing for a while, but steadily getting worse
Pulled dist cap and roter, found the usual signs of arcing, installed backup, not new, and problem lessened!
Anyonelse have similar problems?
Old Oct 19, 2003 | 09:38 PM
JIMBO7's Avatar
JIMBO7
Default Re: '88 L98, getting "pinging under hard acceleration (jackdaroofer)
Same here when I yse 87-88 octane! Up the octane and it goes away! :yesnod:
Old Oct 19, 2003 | 09:42 PM
88_vette's Avatar
88_vette
Hey Jack, bryan here.
Mine did that and it turned out the fuel pump was getting weaker and weaker over time. It started off as a knock only under hard throttle. I backed the timing off and wentaway, but then a few months later it was back. More timng retard, but it didnt go away completely this time. I then noticed the car not running well at upper RPMS. In the end it was the fuel pump, and it took about 12 months for all this to take place. It didn't go bad over night, it took it's time.
P.S your car looks great with those rims. I saw ya the other day. :thumbs:
Old Oct 19, 2003 | 11:08 PM
afree's Avatar
afree
Default Re: '88 L98, getting "pinging under hard acceleration (88_vette)
I would be inclined to check the timing just to be sure it's within spec. If so try backing off a couple of degrees and see if that helps. If so then switching to a higher octane just might be the simple solution. Don't forget to reset the timing back to spec.
To '88 L98, getting "pinging under hard acceleration
