flickering check engine light
Old Oct 16, 2003 | 09:09 PM
atotalnincompoop's Avatar
atotalnincompoop
Default flickering check engine light
i started my '85 pos today for the first time in about 2 months, when i parked it (out of frustration)it ran like crap, now it barely runs, farts and misses, its horrible.
the C/E light just flashes very quickly now, is that i code? i thought that meant the computer was pooched. :confused:
any ideas boys?
Old Oct 16, 2003 | 10:35 PM
atotalnincompoop
Default Re: flickering check engine light (atotalnincompoop)
TTT
nobody here has heard of a fast flashing CE light?
Old Oct 16, 2003 | 10:50 PM
bogus's Avatar
bogus
flickering SES? That does not sound good... not at all.
there is a port under the dash... jump A and B (and I have no clue on an 85) and start to read the flashes... it will code out a message.
12 means you have accessed the diag mode: (5 times)
<flash> short pause <flash> <flash> long pause
Then the code: lets say, 33, just to throw a number, I am not sure of the codes in the 85s. repeats 3 times:
<flash> <flash> <flash> short pause <flash> <flash> <flash> long pause
12 will flash again, then the next code, or, a repeat of the first, of there is nothing else. after the last code, the first will display.
you know... I have a great suggestion... unarse 100.00 and get a helms manual! That will help a ton!!! :D
Old Oct 17, 2003 | 10:29 AM
Steel Blue 91's Avatar
Steel Blue 91
I haven't see one flashing like you discribe. As has been suggested, pull the codes and see if any have been stored. This site: http://www.c4vettes.com/ecm.htm has some good information and procedures.
Good luck.
BTW - how you making out on the targa latch?
Old Oct 17, 2003 | 09:01 PM
atotalnincompoop
Default Re: flickering check engine light (bogus)
thanks andy, i just talked to my chip burner guy, he said that a fast flicker means either a bad computer or a bad chip, i'm almost ready to pour gas on this piece of crap and light her up :mad
anyways, thanks again :cheers:
Old Oct 17, 2003 | 09:03 PM
atotalnincompoop
Default Re: flickering check engine light (Steel Blue 91)
its coming, i'm just trying to figure out how to mass produce it :cheers:
cool site BTW :cheers:
Old Oct 17, 2003 | 09:04 PM
MrNuke's Avatar
MrNuke
:iagree: Could be a bad chip. I jsut tested putting my bone stock '85 vette chip back in the car and I get the same thing you describe. A wierd quick blinking CE light (Looks more like the bulb is shorting and thus flashing a few times a second). Put my current chip back in, everythign back to normal.
Old Oct 17, 2003 | 09:11 PM
atotalnincompoop
Default Re: flickering check engine light (MrNuke)
the guy told me to put my stock chip back in and try it, but i can't find it,
the guy who does my chips is 2000 miles away, i'll have to box up my unit and send it to him(computer and chip)
i really hate this car, i am so frustrated with it, i bet that i have only driven it about 1000 miles in the last 3 years, i just can't get it to run right :mad
give me a chevelle with a holley anyday :yesnod: :cheers:
Old Oct 17, 2003 | 09:35 PM
Steel Blue 91
Ah yes, the good old days. Thrush glass packs, the smell of hydrocarbons and the ability to tune a car with a timing light and a screw driver. :D
To flickering check engine light
