IAC Removal Tool 1990
Old Oct 19, 2003 | 11:04 PM
TRWSD90's Avatar
TRWSD90
Default IAC Removal Tool 1990
Please help with the tool of choice and size to remove the IAC. A second choice, if available would be helpful too. THank you for your help.
Old Oct 19, 2003 | 11:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: IAC Removal Tool 1990 (TRWSD90)
To date I've successfully used:
-socket
-open end wrench
-channle locks
-vice grips
Old Oct 19, 2003 | 11:37 PM
Sam Lam's Avatar
Sam Lam
Default Re: IAC Removal Tool 1990 (65Z01)
Try a "big" adjustable wrench and keep the jaws tight on the IAC. The removal of the IAC is very easy with the throttle body removed. However, I have bypassed the coolant from the throttle body.
Old Oct 20, 2003 | 08:08 AM
jmrl98's Avatar
jmrl98
Default Re: IAC Removal Tool 1990 (Sam Lam)
:iagree: Easiest done when TB off. Big old adj. wrench. :seeya
Old Oct 20, 2003 | 09:40 AM
TA's Avatar
TA
Default Re: IAC Removal Tool 1990 (jmrl98)
Thats what I use :yesnod:
Old Oct 20, 2003 | 09:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I use needle nose vice grips when the TB is still on.
:cheers:
To IAC Removal Tool 1990
