battery replacement 86
Oct 20, 2003 | 06:03 PM
Where are the bolts to remove the panel to get at the battery at the door frame? Found them at the wheel well. If someone knows where it is in the 86 shop manual I have one.
Life is not measured in the breaths you take, but
in what takes your breath away.
Oct 20, 2003 | 06:28 PM
Re: battery replacement 86 (Bear86)
Never mind found it. 6D1-7.
Oct 20, 2003 | 07:40 PM
St. Jude '03-'04-'05-'06-'07
sly little :reddevil arn't they
Oct 20, 2003 | 09:00 PM
See the "88 Battery Removal - How?" thread.
The battery removal instruction I used is from the '85 manual.
Good Luck--remove/loosen the "fender" screws as directed and pull it upward and out.
Mark
Oct 20, 2003 | 09:58 PM
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
While you have the battery out, it's also a good idea to clean off the battery junction to the right of the battery, in front of the firewall.
Oct 27, 2003 | 03:21 PM
ttt
Oct 27, 2003 | 05:23 PM
Re: battery replacement 86 (Mark-44)
OK, what is ttt?
Oct 28, 2003 | 07:22 AM
ttt or TTT means "to the top"
This puts the thread at the top of the forum for more discussion or easier reference. Also a way to say thanks for the question or answer.
Mark
