Re: General questions about a 1990 corvette (Vett6790)
Welcome. :) Top speed for a later L98 is about 154mph. Top speeds for each gear will depend on what gear your differential has in it. You said special gearing, do you know what gear was put into it?
Hello :seeya
'90 models came stock with 3.33 gears. With my mods I was able to feel acceleration in 6th gear, but my speedo wasn't hooked up so I can't tell you how fast I was going. 155mph sounds right for top speed stock. http://www.f-body.org/gears can tell you mph for rpm.
Nice choice, BTW. I also have the FX3 and ZF6 in my '90.
Re: General questions about a 1990 corvette (joecaver)
From my understanding 3:45 can also be found in NON Zr1 ZF6 equipted 90's. I've had mine to 155 at 5200 in 5th and still pulling strong.....but it has a few mods.
