LT1 Waterpump Drive
Old Oct 20, 2003 | 08:29 PM
jmr302's Avatar
jmr302
Default LT1 Waterpump Drive
I need more help with my LT1 project (as usual).
My digital cam is on vacation so a scan of a sketch will have to do.
Should there be an o-ring at the base of the water pump drive on the front of the timing cover? I don't believe there was one on there when I removed the old pump but I know that someone has been in there before. The colored-in portion behind the splines appears to be some sort of seal but it's hard to tell. Definitely doesn't appear to be a worn o-ring or anything.
Thanks again.
PS: engine is a '94 F-body LT1
[Modified by jmr302, 7:31 PM 10/20/2003]
[Modified by jmr302, 7:39 PM 10/20/2003]
Old Oct 20, 2003 | 11:46 PM
jmr302's Avatar
jmr302
Default Re: LT1 Waterpump Drive (jmr302)
TTT
Old Oct 21, 2003 | 12:22 AM
Q1KSLVR's Avatar
Q1KSLVR
Naaaa nothing goes there, the shaft should just slide onto the shaft splines.
Just don't forget to put the shaft on, or it'll overheat in like 2 seconds! (seen it done) :thumbs:
Old Oct 21, 2003 | 08:14 AM
Arctic Trooper's Avatar
Arctic Trooper
The colored-in portion on your drawing is the o-ring (P/N 12553792; there's another identical o-ring on the water pump output shaft). Your drawing looks pretty accurate: it appears that your o-ring is flattened out just like mine was; at first I didn't realize it was a rubber o-ring-- looked more like some sort of plastic bushing. There is no o-ring at the base of the shaft on the timing cover.
Old Oct 21, 2003 | 03:49 PM
Strick's Avatar
Strick
Here is what you should see:
You can see two O-rings, they stop the coupler from moving back and forth.
Old Oct 21, 2003 | 09:08 PM
rockken_vette's Avatar
rockken_vette
Default Re: LT1 Waterpump Drive (Strick)
My new ACDelco water pump came with an o-ring. The original one I took off didn't have it ('94). I used never-sieze on the splines, as there was significant corrosion at 97K miles (I almost could not get the coupler off the old pump!).
Ken
[Modified by rockken_vette, 2:10 AM 10/22/2003]
To LT1 Waterpump Drive
