Engine Builders..nedd Tips on 90 L98
Old Oct 21, 2003 | 03:31 AM
corvette90's Avatar
corvette90
Default Engine Builders..nedd Tips on 90 L98
hi all, i want to rebuild, or lets say make my Engine a little better :-)
ok, here it is
does anybody sell a complete TPI Engine gasket set? which height of head gasket do use?
i have a really nasty cam in it, that only made problems ..so i want to go to this one, waht do you think??
Specifications:
* Advertised duration: 262 intake/264 exhaust
* Duration at .050 in.: 206 intake/210 exhaust
* Gross valve lift: .450 in. intake/.480 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 1,000 to 5,000
* For factory roller engines with stock TPI and computer
also, new roller rockers...
which T-Chain would you recommend??
are there other things to look at??
harmonic damper? motor mounts?
ok, i hope you help me again..
thank you
Old Oct 21, 2003 | 07:55 AM
StephensblackL98's Avatar
StephensblackL98
Default Re: Engine Builders..nedd Tips on 90 L98 (corvette90)
Having recently gone through the same thing, my experience was that I had to purchase the gaskets in two sets: One upper set, one lower. If there is a complete set available, I was unable to locate it. Perhaps I just didn't look long enough. The upper set, by the way, is plenum, runners, distributor base, injector o-rings, and such. The lower is everything else - including oil pan, heads, etc. Go with Felpro.
Old Oct 21, 2003 | 06:17 PM
JAKE's Avatar
JAKE
ok, here it is
Specifications:
thank you
What cam did you have before that you considered to be too nasty?
My vote is the camshaft you're considering is too mild for any real performance enhancement.
Tell us more about your setup and expectations/use for the car.
You'll be a lot better off selecting your gaskets individually rather than in a kit.
Some oil pan gaskets are a lot better than others, same for valve cover gaskets, head gaskets, intake/runner/plenum, exhaust, etc. The idea is to buy the best ones for the job so you'll end up with no leaks.
Jake
[Modified by JAKE, 5:20 PM 10/21/2003]
Old Oct 22, 2003 | 02:54 PM
corvette90's Avatar
corvette90
Default Re: Engine Builders..nedd Tips on 90 L98 (JAKE)
any opinions??
i want just a good daily/weekend driver with normal, not car shaking idle :rolleyes:
Old Oct 22, 2003 | 03:38 PM
gregfloyd's Avatar
gregfloyd
There is a guy on ebay that sells complete TPI gasket sets
I bought one and didnt have any problems
His nick on ebay is PartsDinosaur
Old Oct 23, 2003 | 12:47 PM
corvette90's Avatar
corvette90
Default Re: Engine Builders..nedd Tips on 90 L98 (gregfloyd)
are there any opinions on the cam??
thank you
Old Oct 23, 2003 | 02:04 PM
gregfloyd's Avatar
gregfloyd
If you just want an everyday cam Get a ZZ4 cam.. There are literally always dozens of them for sale on ebay and other forums. They are pulled from new GMPP crate motors that are being upgraded
To Engine Builders..nedd Tips on 90 L98
