Jack Points
Old Oct 21, 2003 | 12:53 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Jack Points
What are the preferred jack points for a '93 coupe? I'd love to get under the thing... but it's so low, and I don't want to break anything!
Thanks to all who reply.
-Ed
Old Oct 21, 2003 | 12:56 PM
Strick's Avatar
Strick
Default Re: Jack Points (eschoendorff)
Hi Ed, First things first. If you don't have one, go out and buy a Helms Service Manual for your year Vette. What kind of jack do you have?
Old Oct 21, 2003 | 01:12 PM
eschoendorff
St. Jude Donor '08
Default Re: Jack Points (Strick)
No jack yet... looking for some advice...
Old Oct 21, 2003 | 01:34 PM
Steel Blue 91's Avatar
Steel Blue 91
Welcome to the forum.
As for jack points, look at the rocker panel on each side. You will see something that looks like this:
/\ Jack point /\
One will be behind the front wheel and in front of the rear wheel.
Old Oct 21, 2003 | 02:11 PM
Strick's Avatar
Strick
For the rear, there is a nice piece that fits on to an axle jack. Look back in the archives for this item. If you plan on doing a lot of work on your Vette, I'd suggest the Kwik-Lift as it is much safer than jacks and jack stands. The other thing to look for is plans for a good drive on ramp. I know someone on here has made ramps that work nicely with the C4 Vette.
Old Oct 22, 2003 | 08:27 AM
eschoendorff
St. Jude Donor '08
Thanks.. I'll look into this. Does anyone have a favorite (read: inexpensive but effective) floor jack that they can recommend?
Old Oct 22, 2003 | 09:18 AM
Ras119's Avatar
Ras119
Try walmart, I found yest. a Two ton floor jack, two-two ton jack stands, and wheel chocks that come in a handy portable(although i don't know where you'd take it?) duffle type bag with carrying strap all for under $30. Its made by AC DELCO.
Old Oct 22, 2003 | 09:34 AM
Strick's Avatar
Strick
When buying a jack, make sure it is the low style jack that will roll under the front of your vette. I bought a 3 ton jack from Northern Hydraulic that has a good lift and sits low enough to easily roll under the front. It was less than $100. Jacks advertise the low measurement and range of lift.
Old Oct 22, 2003 | 11:36 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
For jacking up the rear, this is the only way to go..
http://www.corvettegadgetman.com/products3.html
Works like a charm....
Old Oct 22, 2003 | 03:00 PM
Southern Comfort's Avatar
Southern Comfort
check http://corvettegadgetman.com
Old Oct 22, 2003 | 03:11 PM
85vetteguy's Avatar
85vetteguy
Default Re: Jack Points (vinnies87)
That's awesome. I'm goint to get one of those. Thanks, Guy :thumbs:
To Jack Points
