Thats nice but.....how would you get your allen wrench into this spot to tighten down the bolt? This is number 2 cylinder on my LT4.
For spots like this I use either 3/8" 6 point hex heads or 12 point bolts, and notice behind the bolt is a SS square wire lock washer. While not near as robust of a locking mechanism as them fancy lock washers with a special E clip affair, these work well and I really doubt you could get one of them stage 8 locking do dads in this spot and if you did it would be hell to get it off.
The bolts I used are 3/8NC x 1" long ARP stainless steel bolts. I buy them by the 5 pack or in bulk packs, cheaper that way :)
The dip stick is mounted at the same location using the same factory stud. On my car with the EM headers, I had to delete the Alternator strut. There was no way to make that connection point at the number 1 tube. The AC support struts went back to their original locations using the factory hardware.
Deleting the Alternator strut is OK. There is no structural problems in doing so, 3 flat washers replaced the strut between the Alternator brace and the Alternator body. Once can get a litte fancy and make a spacer for this sport, but I didn't have the means at the time to do so. I don't like using washers but thats all I had available at the time.
[Modified by tjwong, 8:57 PM 10/21/2003]
Did you notice the difference between our two headers? Mine are Hookers. The tubes go in different directions from yours, one reason I went with Hookers. I can get a allen socket on my torque wrench and use it on every bolt. As far as the ac/alt brackets, I just fabricated a spacer and it all went back together just like the General had it. Same with the dip stick.
