AFR's and .015 Gaskets
Old Oct 21, 2003 | 07:36 PM
bigjack's Avatar
bigjack
Default AFR's and .015 Gaskets
I'm contemplating use the fel Pro #1094 head gasket(.015 steel shim with rubber surfaces) with AFR alum heads for optimum compression ratio. Anyone have experience with this combo? Thanks, Jack :confused:
Old Oct 21, 2003 | 07:40 PM
Darkness's Avatar
Darkness
Default Re: AFR's and .015 Gaskets (bigjack)
DAMN, thats one thin gasket, I'd be afraid of it!
Old Oct 21, 2003 | 07:58 PM
87Z-ya's Avatar
87Z-ya
Default Re: AFR's and .015 Gaskets (Darkness)
I use it on my boats engine that has afr 195's. Felpro recomended it due to the fact the boat only uses freshwater not coolant. I went through 2 sets of 1010's in a year, but the 1094's have held up.
Old Oct 21, 2003 | 08:55 PM
ralph's Avatar
ralph
Not sure if thats the same gasket i discussed with felpro last year, but i think it's only good up to 10:1 CR.
To AFR's and .015 Gaskets
