[LT1] Oil Pan Gasket - is it REALLY that easy?
Re: [LT1] Oil Pan Gasket - is it REALLY that easy? (69vetteracer)
Easy job. Couple hours with a lift. Add another without. Have fun. :chevy
It took forever... there was soooo much grease... yuck.
Re: [LT1] Oil Pan Gasket - is it REALLY that easy? (bogus)
I can't stand dirty grease goooo, so I gunked my undercarrige and pressure washed it. Then did the deed. :thumbs:
>>the oil filter adaptor is not that hard... what is hard is removing that damned gasket that turns to concrete.
I had to hit it with a wire brush to burn it off... and it still took 30 minutes!!!!!!
did the old gasket stick to the block or adaptor?
Bogus....What'd you think about those 4 little plastic clips to hold up the pan & gasket while you got everything in position? I thought it was a total life (insanity) saver & again...I can't believe that I've never seen these things before!
Re: [LT1] Oil Pan Gasket - is it REALLY that easy? (greggo's 94LT1)
they did help. No question.
However, cause I was stupid and didn't remove the braces, I snipped them down to fit in the space a bit easier.
I just did my oil pan gasket and rear main seal. To clean that oil filter adapter gasket I used my die grinder with scotch loc discs. They are little scotch brite discs that go on an adapter in the die grinder. The don't remove any metal. I hit all gasket surfaces with these, can't live without them.
Re: [LT1] Oil Pan Gasket - is it REALLY that easy? (Thomastp)
I used a wire wheel on a die grinder. Still took forever...
the leak in mine is on the rear main... but that requires a tranny removal... guess what - I ain't doing it.
