'88 interior light timer location
Old Oct 23, 2003 | 05:14 PM
brookman's Avatar
brookman
Default '88 interior light timer location
My interior lights stopped working with the door switches(both) they will work with the ****. Where is the timer located? I had seen a post about repairing the timer but I can not find it.
Old Oct 24, 2003 | 08:00 AM
efi's Avatar
efi
Default Re: '88 interior light timer location (brookman)
sent you an email! :cheers:
Old Oct 24, 2003 | 09:21 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you sure both pin switches are not stuck in the doors. :smash:
There are 2 switches at each door. :cheers:
Old Oct 24, 2003 | 10:09 AM
brookman's Avatar
brookman
Default Re: '88 interior light timer location (AGENT 86)
I did not elaborate the fact that over the last couple months the lights have been dim at times. I will double check the switches but I am pretty sure it is the controller.
Old Oct 24, 2003 | 10:20 AM
AGENT 86's Avatar
AGENT 86
Dim lights could be poor grounding of pin switch :smash:
Old Oct 24, 2003 | 10:52 AM
Corvette0096's Avatar
Corvette0096
under the kick panel Pass side..
Old Oct 31, 2003 | 11:56 AM
rick lambert's Avatar
rick lambert
Default Re: '88 interior light timer location (Corvette0096)
My 87 had a problem with the timer-the corvette shop where I had the work done said it was discontinued-but after alot of searching they found it,passenger side above kick panel and were able to repair it.
Old Oct 31, 2003 | 12:37 PM
brookman's Avatar
brookman
Default Re: '88 interior light timer location (rick lambert)
Mine was an FM (f'in magic) gremlin. It started working on its' own again.
Old Oct 31, 2003 | 12:54 PM
Corvette0096
Try and find a new one. Once they are gone they are gone.
To '88 interior light timer location
