HELP ! Check Engine Light came on .
Old Oct 26, 2003 | 02:08 PM
HG's Avatar
HG
Default HELP ! Check Engine Light came on .
Check Engine Soon light came on. A friend pulled the code 34. My service manual says M.A.F. sensor. We reset the code, and it came back on after just a few miles of driving and the engine was started. Before I replace that expensive part, is there something that may have caused the code to set. 1988 Stock Thanks for any help. :cuss
[Modified by HG, 2:09 PM 10/26/2003]
[Modified by HG, 2:55 PM 10/26/2003]
Old Oct 26, 2003 | 02:40 PM
Strick's Avatar
Strick
Default Re: HELP ! Check Engine Light came on . (HG)
What does your service manual say to do?
Old Oct 26, 2003 | 02:54 PM
HG's Avatar
HG
Default Re: HELP ! Check Engine Light came on . (Strick)
They describe several test to perform and the bottom line will be replace the MAF
Old Oct 26, 2003 | 02:58 PM
JackDidley's Avatar
JackDidley
Two relays need to be changed just to be safe.
Old Oct 26, 2003 | 03:41 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
change the relays first.. least expensive, if that doesn't do it... then the big one
Old Oct 26, 2003 | 07:14 PM
HG's Avatar
HG
Default Re: HELP ! Check Engine Light came on . (vinnies87)
What two and where are they located
To HELP ! Check Engine Light came on .
