I am having bad brake problems
Old Oct 30, 2003 | 11:21 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: I am having bad brake problems (GiDvEtTe84)
Seems like it. But why does it work when ots warm outside? Very suspicious. It does work better after the engine compartment warms up.
I would say the diaphram gets more pliable when warm. responds to vacuum better
Old Oct 31, 2003 | 04:03 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Re: I am having bad brake problems (Southern Comfort)
Yeah, thats why i changed the booster. I guess it could be bad again. I want to check all my vac lines and see if they are comtracting and causing my vacumm to lose pressure.
Old Nov 4, 2003 | 10:40 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
We had an engineering tech meeting yesterday here at work, the subject of stainless steel tubing came up. Interesting stuff..... Seems some tubing is causing contamination from the inner wall not being properly manufactured???
They're finding microscopic particals coming from the inner walls flaking off.
:banghead: :banghead: :banghead:
